01-14-2020 02:42 - last edited on 09-24-2020 19:06 by
01-14-2020 11:39
01-14-2020 11:39
1. Have you turned down the brightness of the screen? I accidentally did that once and I had to go to a completely dark room to see it and go to settings to change it back!
2. If the screen is completely black: Do a restart. Connect the charger. Hold down the button for 8 seconds until you see the smiley face. That should do it!
Best Answer01-15-2020 04:33
01-15-2020 04:33
I will never recommend a Charge to anyone. I have had many issues! And they aren't resolved! The face is not illuminated today! This is just so ridiculous. It's not a good ad for fitbit!
Best Answer09-27-2020 07:18
09-27-2020 07:18
Have you found a way to solve this issue?
Best Answer09-27-2020 07:35
09-27-2020 07:35
I have the same problem. My Charge 4 was fine until the last update. Anyone had a response? I will raise a support case.
09-27-2020 07:43
09-27-2020 07:43
Did go to dark closet and was so faint. Changed settings but face still not properly lit. Changed face to bigger display. Did a restart. Illumination still faint.
09-27-2020 09:53
09-27-2020 09:53
Best Answer09-27-2020 18:44
09-27-2020 18:44
Hopefully this replies to the thread but Fitbit have been excellent. My unit seemed perfectly fine until the last update. Since then the screen has got progressively worse to see so that now it is unreadable. I got in contact with the Fitbit chat support and they have offered to replace it. I have been emailed with the order and everything. They did ask me to reset and sync while we were chatting but that was it, took about 10 minutes. Nice one.
Best Answer09-27-2020 19:41
09-27-2020 19:41
How did you get a hold of them. The link I followed took me to twitter? I sent them a message.
