05-18-2022 17:21
05-18-2022 17:21
Im new to working out, I do HIIT workouts throughout the week, my heart rate will show I have 48 minutes in Fat Burn Zone but only 10 for active minutes. It made me feel a bit discouraged before I was able to find the heart rate zone area. I thought I wasnt working as hard as I felt I was. Is there a reason for this or way to change it? Maybe even have it show up on my actual tracker if thats available?
05-18-2022 18:37
05-18-2022 18:37
Where are you seeing the 10 Active Minutes?
05-18-2022 20:12
05-18-2022 20:12
I see it on both my watch and the app homescreen, it has a lightning bolt symbol and is by my steps, heart rate, distance, etc.
05-18-2022 20:31
05-18-2022 20:31
My mistake. Charge 3 does give Active Minutes; I was thinking you should be seeing Zone Minutes.
"Active Minutes" require at least 10 continuous activity of certain intensity. You apparently reached that level but usually not for 10 consecutive minutes. In later models the measurement has been changed to "Zone Minutes" instead of "Active Minutes", and dropping the 10 consecutive minute requirement, in accordance with a change in the CDC exercise recommendations.
You can read about the differences here: What are Active Zone Minutes or active minutes on my Fitbit device?
Best Answer05-18-2022 21:16
05-18-2022 21:16
Thank you for explaining this! In a way I can understand as well. Ive been thinking about upgrading to a new one for awhile, maybe its finally time!
05-19-2022 07:19
05-19-2022 07:19
In addition to changing from Active to Zone minutes, the calculation of the heart rate zones also changes, most people finding it harder to reach the newer zones, though able to get credit for shorter times in zone.
