02-08-2016
07:09
20:15
02-08-2016
07:09
20:15
my fit bit HR will not sync. the time and date are stating its yesterday and it will not sync to the app on my samsung. when i try to sync it stats could not sync to live data. i have tried all of the trouble shooting. reset 3 times in a row. turned on and off bluetooth. reinstalled the app. removed my device from the app them re-added it. restated my phone..... i have tried countless times and have spent the last 2 hours tying to fix it. my fitbit is only 1 month old. please help!!!
09-13-2016 12:56
09-13-2016 12:56
trying to sync new fitbit 11. my phone is paired fitbit 1. how do I get it to reconize new fitbit?
Best Answer09-20-2016 04:58
09-20-2016 04:58
@kris123 A warm welcome to our Fitbit Community! I would like to follow up and would like to know if you were able to get your new tracker connected or if the issue persists.
Looking forward to your reply my friend! ![]()
Best Answer10-19-2016 10:47
10-19-2016 10:47
Best Answer10-20-2016 05:12
10-20-2016 05:12
@TrayJon Thanks for joining us and welcome to our Fitbit Community! In order to avoid any confusion on my end and I can assist you better, I would like to know if you are asking if your history will be erased since you would like to perform some troubleshooting steps? If so, what issues is your tracker experiencing?
See ya later my friend! ![]()
Best Answer10-20-2016 07:03
10-20-2016 07:03
Best Answer10-20-2016 19:10
10-20-2016 19:10
Best Answer10-20-2016 19:35
10-20-2016 19:35
Best Answer10-21-2016 06:55
10-21-2016 06:55
10-21-2016 08:31
10-21-2016 08:31
Best Answer01-04-2017 07:36
01-04-2017 07:36
Yes mine
@max04 wrote:I got my charge HR for my birthday this Saturday. It set up fine and was working perfectly till yesterday. It will not sync and i have tried everything. I have even tried to reset the fitbit itself and it won't reboot. I kept my finger on the button for at least 30 seconds and i just had the battery image the whole time. I've tried this several times with no joy. Has anyone else had this problem? I've contacted fitbit with no response.
Best Answer01-12-2017 11:43
01-12-2017 11:43
How do u do that
Best Answer01-12-2017 12:51
01-12-2017 12:51
Best Answer01-12-2017 13:35
01-12-2017 13:35
Hi, can you tell me what you did? I'm so frustrated with mine! Thanks 😕
Best Answer01-13-2017 00:17
01-13-2017 00:17
Best Answer08-17-2020 06:21
08-17-2020 06:21
It did not work for me and after taking it off with a full charge-it was down to almost no charge this morning
