05-17-2021
11:15
11:20
WilsonFitbit
05-17-2021
11:15
11:20
WilsonFitbit
My charge 3 stopped vibrating all together. I checked all the settings and tried resetting while it's on the charger several times. Is there anything else I can't try.
Hello @Bell16112. Welcome to the community forums!
Thank you for the detailed information and for the steps you've followed. May I confirm which settings did you check? Note that when DND is on, notifications, goal celebrations, and reminders to move don't cause the tracker to vibrate or the screen to turn on.
Note that you can't turn on do not disturb and sleep mode at the same time, but if Do not Disturb isn't on, I recommend checking Sleep Mode. Sleep Mode is another setting that will prevent the following, when it is activated:
I also suggest performing a long restart. A long restart is different than the basic restart and you can complete the process by following the instructions below:
I look forward to your response.
@Bell16112 Thanks for your reply.
I'm glad to hear that the inconvenience is now resolved! Hope you can continue tracking towards your fitness goals!
Have a great day!
