04-26-2017
06:31
09:49
04-26-2017
06:31
09:49
I've got the Fitbit Charge 2 and have had the new update on my app of the R.E.M. Stages graph for a while now however all it ever showes is 'no stages'. Why is this? Very frustrating as I really would like it to work.
04-26-2017 06:34
04-26-2017 06:34
Sleep stages has not yet rolled out to all Charge 2 fitbits. It will arrive at some point but fitbit are not saying when the rollout will be completed.
04-29-2017 05:25
04-29-2017 05:25
Mine showed REM on Thursday night, but not last night
04-29-2017 05:49
04-29-2017 05:49
Fitbit suggest there could be a few reason for this:
"WHY DON'T I SEE SLEEP STAGES TODAY?
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
taken from: https://help.fitbit.com/articles/en_US/Help_article/2163/
05-01-2017 14:41
05-01-2017 14:41
Mine also has suddenly stopped. Has been fine from 26th March, but stopped on Sunday night. Nothing has changed with the fit and would be surprised if my sleep method has suddenly changed. Still shows restless and awake but the look seems to have reverted back to the early March appearance.
05-01-2017 14:50
05-01-2017 14:50
I have a friend w same Charge 2, same software update and settings, she gets REM information I don't?
Best Answer05-01-2017 15:56
05-01-2017 15:56
I think you have to choose 'log sleep'. When I do that, I get REM etc. If I just go to sleep, I get the old report.
Best Answer05-01-2017 16:37
05-01-2017 16:37
Now you see it now you don't!! Had sleep stages for 2 nights, for the last 2 nights it has gone, reverted back to the old format?!!!
05-01-2017 17:53
05-01-2017 17:53
I checked my last app update and it was carried out on April 25th. But, the REM stats etc. Were still working on the 29th. So, likely not the app but does seem odd. Really like the new format, so hoping it will return.
05-01-2017 18:39
05-01-2017 18:39
05-01-2017 18:39
05-01-2017 18:39
05-02-2017 01:32
05-02-2017 01:32
Same thing is happening to me 😞 Worked once and now i don't see the detailed chart. Also is the chart accurate. It shows i was restless last night but i got gr8 sleep. showed only 15 minutes of REM
05-02-2017 04:47
05-02-2017 04:47
Ok, so today it is back again. Seems fairly representative as I sleep badly with a lot of awake and restless. I will check to make sure the band is always at the same setiing, my adjustment varies a hole especially if I have done a late workout.
Best Answer05-02-2017 05:59
05-02-2017 05:59
So far I have had ONE night with sleep cycles (this past Sunday)... doing everything as usual.
Best Answer05-31-2017 23:24
05-31-2017 23:24
Mine show the stages on Monday night but not last night. Goofy electronics. Thought at first it was just me. I have a habit of messing up anything electrical:). Hope for soon
Best Answer01-08-2018 06:10
01-08-2018 06:10
I have a Samsung S8, and I use the Fitbit charge 2. I found that the only time it shows REM, light, deep sleeps and what not is if I leave the Bluetooth on while sleeping.
Best Answer01-09-2018 15:12
01-09-2018 15:12
Tried all suggestions by Fitbit- none worked and still no REM etc stages graph . VERY DISAPPOINTING !!??
Best Answer01-09-2018 19:31
01-09-2018 19:31
01-09-2018 19:31
01-09-2018 19:31
Did you try leaving the Bluetooth on, on your phone all night. That's the only way it works for me
Best Answer01-10-2018 01:39
01-10-2018 01:39
I will try if it works tonight
