04-11-2020
02:29
10:02
04-11-2020
02:29
10:02
I haven't used my charge 2 for over a year. Today I put it on charge and turned it on, it said I had 100% battery so I used it straight away. After 5 hours or so it randomly turned off and now won't turn back on.
Is it because I haven't used it in so long? Or will it not work anymore?
04-13-2020 06:16
04-13-2020 06:16
Mine sometimes goes black after I put it on the charger. I usually put it back on the charger for about 10 minutes and then hold down the button until it comes back on. When this happened to me, I couldn't find an article explaining how to reset a Charge 2, only a Charge, so maybe I was actually just resetting it (I wouldn't know). It also may be updating if you have automatic updates turned on. Give it some time and charge it again for a bit and if that doesn't work, contact customer support.
04-12-2020 00:52
04-12-2020 00:52
hello, I have a cocompletely blackscreen this morning. It's just 5ge screen I cant get kn but the lights are on underneath it! So frustrating
Best Answer04-12-2020 10:06
04-12-2020 10:06
happened to me a few days ago, can't figure it out.
Best Answer04-12-2020 10:08
04-12-2020 10:08
So annoying, it feels too that Fitbit have a certain life span:0-(
Best Answer04-13-2020 06:16
04-13-2020 06:16
04-13-2020 07:13
04-13-2020 07:13
Thanks so much, I will give it a rest then recharge 👌
Best Answer04-13-2020 17:37
04-13-2020 17:37
This is what I ended up doing & it worked for me so fingers crossed!
