03-27-2021
03:43
04:20
WilsonFitbit
03-27-2021
03:43
04:20
WilsonFitbit
Hi, this is the first time I have got my Fitbit wet I dropped it in the sink, it now has like a greyish back ground where it look like the pixels where affected, this is supposed to be waterproof, my warranty has run out, is there anything I can do. Thank you
03-27-2021 04:26
03-27-2021 04:26
Hello @tigertotiger Welcome to the community forums!
Thank you for the information! Your Fitbit Charge 3 is water-resistant. Since this got wet, it’s important to take it off and dry it well before putting it back on. If your device comes into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser (like Cetaphil) and dry it with a lint free-cloth. You can confirm this information here.
In addition, I recommend performing a restart following the steps provided in the following link: How do I restart my Fitbit device? If the inconvenience persists, my best recommendation is to perform a long restart which is different than the basic restart outlined above.
Hope this helps!
Best Answer03-28-2021 09:47
03-28-2021 09:47
Best Answer03-29-2021 04:34
03-29-2021 04:34
@tigertotiger Thank you for following the suggested troubleshooting steps!
Since the inconvenience has persisted, the best way to get assistance is to contact our Support Team. You can click here to get connected.
See you around.
