06-22-2021
17:43
04:48
WilsonFitbit
06-22-2021
17:43
04:48
WilsonFitbit
Yesterday my charge 3 just...died. It had plenty of charge, but it just went black and even when I did put it on the charger, nothing happened. Anyone else have this issue?
Moderator edit: subject for clarity/label
06-25-2021 04:27
06-25-2021 04:27
@Badbekah Thank you very much for your reply and for following the tips.
Since the issue has persisted, my best recommendation is that you please contact our Support Team for further assistance. Note that you can contact them through chat or over the phone, but phone waits have been longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
06-23-2021 04:52 - edited 06-23-2021 04:52
Hello @Badbekah. Welcome to the community forums!
Thank you for the detailed information. If your Charge 3 isn't charging now, I'd recommend performing some troubleshooting steps suggested in this help article: Why isn't my Fitbit device's battery charging?
If that doesn't help, I suggest performing a long restart by following the steps below:
If these steps work and your Charge 3 turns on and it starts charging again, please make sure that it is updated to the latest Firmware version; otherwise, you can perform the update by following the instructions here.
On a side note, I've moved your post to the Other Charge Trackers board to keep our forums organized.
Hope this helps.
06-24-2021 18:32
06-24-2021 18:32
06-25-2021 04:27
06-25-2021 04:27
See you around.
