12-20-2018
02:10
20:07
12-20-2018
02:10
20:07
I have tried everything suggested and it said my fitbit had updated but I haven't been able to sync it since the 8th November and now even the time has gone funny on it so I can't even use it as just a watch. No idea what the heck is going on with it. It's a Charge HR. My dad has tried for me, I've tried, my Fianceè has tried with no joy......
Any help would be much appreciated.
Moderator edit: Updated title for clarity
12-20-2018 08:49
12-20-2018 08:49
My my Fitbit charge HR is not syncing it hasn't for months. I tried to download again and no luck
12-20-2018
13:58
07:32
12-20-2018
13:58
07:32
Hi there @Onak @GemHv, welcome to the Fitbit Community Forums! 🙂
I'm sorry to hear that you both are having problems getting your Charge HR trackers to sync as they should. Thanks for what you've tried to get it to work. I'll be happy to help you out!
I'd like to provide some suggestions in the case you've not tried them.
-Make sure you're using a compatible mobile device. To see the list of compatible devices, you can click here.
-Give your Charge HR a restart.For this, plug the charging cable to any USB port or UL-certified USB wall charger and plug the other end to your Charge HR. Press and hold the button for 10-12 seconds until you see the Fitbit icon and the version number and release the button.
-Make sure you're on the latest version of the Fitbit app and the latest version on the OS of your compatible mobile device.
-If you're still having problems, you can try to remove your tracker from the Bluetooth devices. For this, go to the Bluetooth settings on your phone. On your connected devices, look for your tracker. Tap on it, then choose the option that says "Forget this device". Then, proceed to set up your tracker as a new device.
-For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Hope this helps. Please, let me know if you still need more help after this!
12-20-2018 14:15
12-20-2018 14:15
Best Answer12-27-2018 03:19
12-27-2018 03:19
Thank you for all of this.
I had already tried all of what was advised, but gave it another go JUST INCASE. Deleting device and 're adding. Getting rid of the app completely and 're adding. Restarting the Charge HR. nothing has worked the device STILL isn't syncing, and the time is still wrong so can't even be used as a watch anymore. I don't know what to do. I even have new straps for it as a Christmas gift to go with different outfits for work etc as wore it all the time, but can't wear it at all anymore. I'm at my whits end with it now. If there is ANY THING else that can be tried please let me know because I don't know what to do with this expensive heap of junk right now. It was ABSOLUTELY FINE until this bloomin update and since then it's stopped working completely. Hasn't synced since November 8th 2018 I think it was.
Many Thanks and Kindest Regards
Gemma
Best Answer12-29-2018 09:23
12-29-2018 09:23
This is a widespread problem with the Fitbit Charge HR. Fitbit's way to resolve this is have you buy a new one. How about they just fix the problem on their end. It happened right after the update. They are going to lose a lot of customers over this. I refuse to purchase another one when mine is working perfectly fine except for syncing. They will keep giving you the same robotic responses they they give to everyone. It's sad that they don't value their customers more. I will be looking into another devise other than Fitbit.
12-29-2018 16:49
12-29-2018 16:49
Have tried all the things you suggested. Nothing works. Now what??
12-29-2018 17:03
12-29-2018 17:03
Best Answer12-30-2018 00:55
12-30-2018 00:55
Same problem here. Tried all the suggested fixes and none work.
So now have a watch with the wrong time, that will not sync and so is completely useless !
12-30-2018 06:54
12-30-2018 06:54
Best Answer12-30-2018 11:47
12-30-2018 11:47
Best Answer12-30-2018 12:09
12-30-2018 12:09
12-31-2018 08:41
12-31-2018 08:41
Im looking for a different device now, too. It takes hours of trying every trick in the book to get the time right and get it to sync. An expensive and aggravating PC of junk.
Best Answer12-31-2018 08:52
12-31-2018 08:52
01-03-2019 07:08
01-03-2019 07:08
I got mine working, for now. I unpaired it, restarted my phone, paired Fitbit BK to my phone and synced it. Looked a little later and the time was right..this is after hours of research on Google. So maybe restarting the phone got rid of old connection to Fitbit. I have no clue.
Best Answer01-03-2019 09:28
01-03-2019 09:28
Best Answer01-04-2019 11:19
01-04-2019 11:19
I have the same problem as well. I have tried everything and it is still not working. I wanted fitbit because it will link to my Myfitnesspal app but this is ridiculous!!! I will be trying a different brand!
08:46
08:22
01-16-2019
08:46
08:22
Hello everyone. Sorry to hear that your Charge HR isn't syncing. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional instructions for both phones and computers here.
Let me know how it goes!
Best Answer01-18-2019 14:57
01-18-2019 14:57
Best Answer01-18-2019 15:04
01-18-2019 15:04
I was Nellnell5kids and couldn't sign in under that name but this is what I did. I don't know why they won't share this anywhere else. I had to do it twice but now it is working just fine. I will have to put this in more than one post so hopefully they show up together.
Find below the steps to factory reset your Charge HR.
