04-23-2016
21:00
07:34
AndreaFitbit
04-23-2016
21:00
07:34
AndreaFitbit
Dont charge your Fitbit with a wall charger!!!!!!! I bought my first Fitbit charge in mid February....after the first day or 2 of using it, the battery would last no more than 2 days. I contacted support, and they were pretty helpful and sent me a replacement within a few days. That second Fitbit had the same issue right when I got it...battery would last no more than 2 days even though Fitbit claims it lasts 5-7 days. And this was after turning off all the "extra" features... (Quick view, alarm, caller ID, etc). I contacted Fitbit again, notified them of the issue and again, they were helpful and sent another replacement (which I'm greatful for..great job to Fitbit for your customer service..it's excellent). When talking to customer support for the second time, I specifically asked them whether it was ok to charge Fitbit with a wall charger instead of though usb. Customer service assured me that as long as the wall charger was not a knock off it would be fine (I was using the wall charging block that came stock with my iPhone 6). I'm now on my 3rd Fitbit, and with this one I ONLY charge it with my computer, and it still works fine after nearly a month. My battery lasts about 7 days as of now. if you are having battery issues and get a replacement, I would recommend you only charge it with the usb cord and your computer and not using a wall charger. And Fitbit...I think you guys need to do some more research and see whether or not using wall chargers negatively affect the Fitbit battery and fix the issue if it does. Even though you say it doesn't, based on the 3 fitbits I've had since mid February, I'd say it does. It is so much more convenient to be able to charge with a wall charger instead of a computer, but not if it ruins the Fitbit!! But overall, very pleased with the product and their customer support
Moderator edit: format and label.
04-24-2016
07:40
08:26
04-24-2016
07:40
08:26
@itsladyj Welcome to the Fitbit Community! Fitbit will recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Also, other tips to best charge Fitbit trackers are:
- Use only genuine Fitbit charging cables.
- Use only UL-certified wall chargers.
- Avoid USB battery packs.
- Charge at room temperature.
Hope this helps. Keep up the supper stepping! ![]()
04-24-2016 10:45
04-24-2016 10:45
04-24-2016
11:13
07:44
04-24-2016
11:13
07:44
@mythlyn Welcome to the Fitbit Community! To contact customer support; click here! Make sure to check your warranty first.
Keep me posted! ![]()
04-24-2016 19:23
04-24-2016 19:23
04-24-2016 19:31
04-24-2016 19:31
04-25-2016
10:19
07:43
04-25-2016
10:19
07:43
@itsladyj I hope you're doing well! I'm really glad to hear that your Fitbit tracker is working properly now. I'm pretty sure your advice will help a lot of users with battery issues. Thanks for the positive contribution to the forums.
Yes, you can contact support via phone, chat, or email. Chat is easy and fun!
See you around! ![]()
05-12-2016 14:39
05-12-2016 14:39
Hi SantiFitbit, have absolutely no complaints with my Flex other than it is just sugh a pain to charge. The service and complaints people at Fitbit are great and don't hesitate to help. But. The reliablility of the charging system for the Flex is very poor and this has for me, cancelled out the very good side of the Flex.
06-02-2016 09:55
06-02-2016 09:55
06-02-2016
13:22
07:43
06-02-2016
13:22
07:43
@Mcgowan I'm glad to hear that the service has been great for you. If you feel that your charging cable or tracker are not working fine or loose; report it to customer support as they may replace it for you. ![]()
@StepitupMama You can wait for the battery to be fully drained or you can charge it when its about to completely drain. You should get an email notification every time your tracker have low battery. If you wish, you can charge it once you receive the email low battery notification.
Hope this helps! See you around!
06-02-2016 17:53
12-24-2016 19:01
12-24-2016 19:01
01-19-2017 06:38
01-19-2017 06:38
You said "What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all. "
What is considered excessive charging time? Overnight? 4hrs? 3days?
01-19-2017
07:13
07:43
01-19-2017
07:13
07:43
@Wolflead6 I hope you're doing well! Good question! I would recommend charging your Fitbit tracker no more than 2 hours. It will be fully charged in 2 hours or maybe less. I would consider it excessive leaving it overnight for instance.
@scorpioev That's unfortunate. Thanks for your feedback. I have heard that the Fitbit Charge 2 is working very good, even with charging aspects! It is the improved version of the Charge HR, the new generation of Fitbit trackers. Hopefully, the Community will be able to see you back with Fitbit!
02-08-2017 11:20
02-08-2017 11:20
So are we saying leaving an Alta hooked up to charge over night on a wall charger is a bad thing?? I too am now experiencing a reduced battery life on my Alta.. charged is Sunday night and here it is noon on Wed and I have a low battery alert.. use to easily get 5 days with no problem...
02-09-2017 01:05
02-09-2017 01:05
I am having exactly the same problem with my Fitbit !! Love it but it won't hold it's charge beyond 24hrs. Likewise I have been using my iPhone charger
03-26-2017 23:19
03-26-2017 23:19
My Alta isn't doing anything when connecting to the charging cable. No vibration, nothing on the screen, tried different USB ports, nothing seems to work. Is there anything else that I could try that I've missed?
04-11-2017 08:30
04-11-2017 08:30
Have you done a restart with it plugged into a computer??
Best Answer04-18-2017 14:35
04-18-2017 14:35
Call the customer service number on the website. They will replace your fitbit if it is under warranty still
Best Answer04-24-2017 04:59
04-24-2017 04:59
@SantiR wrote:@itsladyj Welcome to the Fitbit Community! Fitbit will recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Thank you for this info and easing my mind.
