01-15-2018
17:21
17:01
01-15-2018
17:21
17:01
My fitbit charge is stuck on a screen. I was in the process of updating it and now it has the updating bar with a warning symbol in the middle and i can't get it to turn off or anything? what can i do?
01-16-2018 04:28
01-16-2018 04:28
Hello @haileywalsh, it's great to have you on board, welcome to the Fitbit Community! ![]()
Thanks for bringing this to my attention, at this moment I would like to suggest you to go to your phone's Bluetooth Settings and check if your Charge is on the list of paired devices. If it is, select it and forget/remove form this list. Then, start the update again, your Charge will now be able to finish it and the screen will no longer show the half-filled bar with an exclamation point.
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
01-22-2018 06:05
01-22-2018 06:05
Hi Marco.
This does not fix the issue. Please help!
Best Answer01-22-2018 06:08
01-22-2018 06:08
disconnecting from Bluetooth does not fix the issue
Best Answer01-22-2018 18:59
01-22-2018 18:59
Mine did the same thing was very frustrating but I saw this entry and tried it and it worked. Thanks
Best Answer01-23-2018 03:18
01-23-2018 03:18
Hello @BrittneyD and @rlsmine, thanks for joining the conversation, it's a pleasure for me to welcome you to the Fitbit Community. ![]()
@rlsmine, I'm glad to know your issue has now been resolved, thanks for letting me know, I appreciate it.
@haileywalsh, I appreciate you have tried the troubleshooting steps described above, at this moment I would like to suggest you to set up your tracker as a new device to force the update to finish. Don't worry, none of the information previously stored in your account will be deleted.
To set up your tracker as a new device:
I hope this can be helpful, give it a try and let me know the outcome!
01-24-2018 09:41
01-24-2018 09:41
Your last recommendation does notwork eithr.
Best Answer01-24-2018 15:06
01-24-2018 15:06
I also tried installing the update and now my Fitbit Charge's screen shows a half complete bar with an ! in the center. I followed your previous advice and now that I've removed my Fitbit Charge from my list of known devices, it is no longer "findable" on my iPhone. I even tried to install it on my new Mac and no luck, it can't "find" the device either. What now??
Best Answer01-25-2018 01:58
01-25-2018 01:58
Mine is doing the same very frustrating
Best Answer01-25-2018 19:28
01-25-2018 19:28
I’ve tried everything they’ve said doesn’t work don’t sell them if this is a huge problem if I can’t get this to work I will move on.
Best Answer01-28-2018 06:34
01-28-2018 06:34
Same problem here. I hadn't used it in a while because I bought the blaze. Got it out and triend to set it up for my son and I keep getting the same error. If I delete it out of my account and put it back on the charger for a bit the error will go away but every time I try to update it I get the same error.
Best Answer01-28-2018 23:48
01-28-2018 23:48
It worked for me , thankyou!!!
Best Answer01-29-2018 20:16
01-29-2018 20:16
This has been helping some when you get stuck on your update.
https://community.fitbit.com/t5/Charge-HR/Fitbit-froze-during-update/m-p/2303997#M191379
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
01-31-2018 19:21
01-31-2018 19:21
Mine was having the same issue and the new device set up worked! Thanks so much!
Best Answer02-01-2018 03:29
02-01-2018 03:29
Hello @LaurenSon, have a warm welcome to the Fitbit Community, thanks for joining us! ![]()
I appreciate you have shared your experience with us and that your tracker's issue was resolved by setting it up as a new device.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
05-27-2018 06:56
05-27-2018 06:56
My Fitbit Charge is stuck at the half loaded update screen and it has been like this for the whole night. I tried plugging it in to the charging cable and pushing the button down for 12 seconds but all it does is just turn the screen off, vibrate, and then the screen turns back on and it is still stuck at the update screen. I also tried checking my Bluetooth, but on the Fitbit app, it doesn't even show that i can update my Fitbit. It is like the app thinks that my Fitbit is all done updating but the update screen is still stuck on the Fitbits screen.
Best Answer05-28-2018 07:13
05-28-2018 07:13
Hello @lexieb122507, thanks for joining the conversation, it's a pleasure for me to welcome you to the Fitbit Community. ![]()
I appreciate you have let me know the troubleshooting steps you've tried so far. At this moment, if your tracker is still showing the half-filled bar and the app is not showing you an available update, my best recommendation would be setting up your tracker as a new device to force the Charge to finish the process where it got stuck. Don't worry, none of the information already stored in your account will be deleted.
05-11-2020 22:17
05-11-2020 22:17
My Fitbit keep turning off and on during an update. I’m getting stressed out because it’s been updating all day and now it’s doing this.
Best Answer01-21-2021 18:11
01-21-2021 18:11
My Fitbit does the same thing but the name is not in my recent paired and I disconnected my Fitbit from my phone plz help me
