11-01-2020 09:43
11-01-2020 09:43
Fitbit Charge 2 won't sync battery is lasting only 2 days. Tried uninstalling app, restting device checking bluetooth evrything suggested in the forums. tried to redo the setup process and It connects to my phone gives me a 4 digit code which I put in but won't pair. My dashboard is a mess at this point.
What I have done:
Fitbit app has been reinstalled and is up to date.
Restarted the fitbit
Do not have another device to try pairing with
Permissions for location are on.
The app is set to all day sync
No other any bluetooth devices registered.
The Fitbit and Phone is fully charged.
Cleared Fitbit App cache and Data
Stopped and startedg bluetooth and restarting the fitbit
Tried deleting data
Tried starting a new setup gives code but won't pair
11-02-2020 20:43
11-02-2020 20:43
I had the same issue - Charge 2 but with the Pixel 3a, tried all the steps indicated and had the same results.
I FOUND A WORK AROUND reading through all sorts of guides online. Find another device - I used an old phone (an original Pixel) - and install the latest Fitbit app on it and set up the Charge 2 as a new device. I followed all the steps, but instead of failing at the 4-digit code it accepted the 4-digit code and then connected. It was then paired with my old phone and would sync beautifully.
I restarted my current phone (Pixel 3a) and the Fitbit app. I assume something in the Fitbit app did a sync to my account, because the Charge 2 suddenly appeared as a connected device. Another device also appeared, but I've since removed it without issue.
See if you can set it up on another device - be sure to use your same Fitbit account.
My sync initially stopped on Sept 27, 2020, and I performed all the above steps on October 10, 2020. I've been able to sync fine with my Pixel 3a since this. I turned off my old phone and it hasn't been on since.
HOWEVER, prior to Sept 27, I would easily get at least 5 days on a full battery charge. Since reconnecting, I have about 30-35% battery drain daily, which means I have to fully charge it every other day to avoid any 'low battery' notifications. When I open the Fitbit app, the stats are very up to date as if it is constantly connected, and I can't find any option in the app to prevent it from being constantly connected. Old version of the app had it, but I can't find it now. Coincidence, or related to the initial sync issue? I don't know yet.
Best Answer11-07-2020 03:04
