Fitbit Flight game
My Fitbit Charge 2 now has a game called Fitbit Flight. Where did this come from and how do I remove it? In the Android Fitbit app it does not appear in Menu Items so I am unable to remove or reposition it.
My wife's Charge 2 does not have the game for some reason!
Any help appreciated...
Thanks
364 REPLIES 364
it came up on my watch after i went for a walk yesterday and hit my goal but i have never noticed it before when hitting my goal.
Welcome to the community @we123 , the reason you might not have seen the game before is because it will not be activated until all five goals are met. The five goals are Steps, Distance, Calories, Floors, and Active Minutes.
Congratulations on meeting all 5 goals!!
you can get out of the game by putting your fitbit back on the charger like you are going to charge it.. hold the button down until you see the fitbit emblem , then take if off the charger, it should put you back to the regular fitbit stuff..
@tracycallas you can also get out of the game the same way you back of any menu, which is the same way a person stays the game.  Simply hold in the button until the unit vibrates and the screen backs or off the game. No charger needed.
Note that this did not work for the second release firmware but that was several versions ago.
that didnt work, holding the button until it vibrated..but thank you!
You play like flappy bird and each time you press the button it jumps
You can get rid of it by holding the button
its called flappy bird aka fitbit flight
You play it by pressing the button on the side of your Fitbit
my fitbit charge 2 also had this and i found out about it last night for the first time then after i played for a while it disappeared.!
good directions but I dont have the game😀
Per giocarci devi cliccare il tasta sinistro
@BaPate39 as mentioned above, you will only get the game after reaching your goals for daily step, calorie, distance, active minutes, and at least 250 steps for each of your active hours. If the user has chosen not to have any active hours, they will never get the game.
Also the game will only show on the Charge 2.
How do you guys manage to get flight bird in the first place ????
Hi @Nibble122 Please read my post immediately above yours.
First make sure that you have a few hours to monitor for 250 steps, now set your goals so that they are not out of reach.
Be sure that you hit all of your Fitbit goals, your game will be on the last screen.
my high score is 209 hehe
if you finish all your goals you get it until midnight
On 5/31 I walked 10 miles and found an icon on my fitbit that looked like a person standing on a castle and question marks under it. I didnt click on it. I tried to research it and couldnt find anything. It was not on my fitbit the next day. On 6/3 I walked 11.85 miles and the castle icon was on my fit bit. It is the fitbit flight game. I played it and today it is gone.
You must have a charge 2 @Slj06 since this model is the only one that offers a game for hitting all your daily goals
If you have the Fitbit flight game on your charge 2 it means that you have completed all your activity goals for the day, after midnight you should no longer have it and you must complete your activity goals to get it back.
