01-11-2017 14:14 - last edited on 09-09-2020 10:13 by MatthewFitbit
My Fitbit Charge 2 now has a game called Fitbit Flight. Where did this come from and how do I remove it? In the Android Fitbit app it does not appear in Menu Items so I am unable to remove or reposition it.
My wife's Charge 2 does not have the game for some reason!
Any help appreciated...
Thanks
10-01-2018 08:23
10-01-2018 08:23
You cannot fall on the little things that look like castles, also you can't fall into the blackness of the screen. Hope this helps!
@Way2Far wrote:My Charge 2 has also just got this game installed. My question is how do you play it.
10-01-2018 08:24
10-01-2018 08:24
All you have to do is ignore it, it does not do anything to disturb you, actually it is quite fun!
10-27-2018 07:15
10-27-2018 07:15
Last night I had the game woke up this morning a and I don’t have it
10-27-2018 08:31
10-27-2018 08:31
@Workout2023 yesterday you hit all your daily goals, today you haven't hit them yet. Once all your top goals go green you will have the game.
11-06-2018 13:29
11-06-2018 13:29
Cheer up it's not the end of the world
If your surrounded by little kids who like seeing the colours light up when they tap it it's actually pretty fun
11-08-2018 05:48
11-08-2018 05:48
That makes no sense. I said that I would recommend it being permanently added or where you could add it to your Fitbit because when I try to reach my goal, it does not work.
11-09-2018 10:42 - edited 11-09-2018 13:40
It is not just one goal that needs to be reached.
Steps
Calories
Distance
Floors
Active minutes
If one of the above goals are not meet, then no game will be offered.
11-09-2018 12:52 - last edited on 02-24-2020 13:43 by LiliyaFitbit
I get the Flappy Bird game when I’ve met all of these daily goals:
Steps, active minutes, Flights/Floors, Steps
and steps per working hour…
After midnight the game is gone and must I ‘earn’ it again😓
You can enter and leave the game by pressing & holding the button of the
Fitbit for at least a second.
Happy exercizing!
Met vriendelijke groet,
11-14-2018 13:09
11-14-2018 13:09
Mines gone after one night my game disappeared when I woke up but I have hit all my goals and still not back I liked the game and I’m wanting to know what happend any ideas ?
11-14-2018 13:55 - last edited on 02-24-2020 13:44 by LiliyaFitbit
Reach all goals again…
All daily goals and steps per (working) hour…
12-09-2018 20:52
12-09-2018 20:52
I have the ionic it has a good amount of games
12-09-2018 20:54
12-09-2018 20:54
I have the ionic, it has a good amount of games.
12-27-2018 12:58
12-27-2018 12:58
Might it have something to do with the chatter setting?
01-03-2019 01:37
01-03-2019 01:37
I have completed all my goals and updated the app but it’s still failing to work
01-03-2019 10:54
01-03-2019 10:54
@Audem after sycing your tracker, is your David all green?
On In addit your active hours will also need to be all filled. For me this would need to read 11 of 11.
01-08-2019 23:52
01-08-2019 23:52
To play you press the button on the dues of your Fitbit.
01-26-2019 17:23
01-26-2019 17:23
I can’t get Fitbit flight and I did my goals plz help me
01-26-2019 19:26
01-26-2019 19:26
@Danny1001H first I'm assuming that you have a Charge 2 since this the only model that has this option.
When you say that you hit all your goals. Your whole dashboard should be green and all your active hours will need to be full.
Now tap the button till you see the new option for the game .
02-07-2019 18:47
02-07-2019 18:47
You press the navigation button on the side to keep the little person afloat without hitting the castles above or below.
03-14-2019 16:57
03-14-2019 16:57
You get it when you hit all your goals and it should only last until midnight
