11-17-2017
00:56
20:15
11-17-2017
00:56
20:15
Charge HR froze last night during update. ☹️ now not functioning at all. Had bar across screen half is shaded and half clear with an exclamation mark at times. 😩
Thanks for your advice. I had the same problem of my Fitbit freezing in the middle of an update, but your instructions worked perfectly. Appreciate it much!
Best AnswerThanks for that info. I told my Iphone to forget my Fitbit. My Iphone then automatically picked up my Fitbit and the update download continued. I had my Fitbit plugged into my Imac BTW.
It is now charging as normal. Fingers crossed 🙂
Best AnswerThanks! That worked perfectly. I think I'll just skip the update though.
