03-11-2016
		06:22
		20:15
		03-11-2016
		06:22
		20:15
My fitbit stopped during the firmware update last night, and now it will not complete the update or sync. I have done everything- restarted it, my phone, uninstalled the app- it's just stuck, and no longer functioning. Anyone else have this issue and you were able to fix it? It just turned itself off, even though it had a full charge. I'm guessing it's just broken now.
Anyone else have this issue and you were able to fix it? I'm so disappointed. I was looking at upgrading to the blaze, but I'm afraid to now that this has happened- what if it has some sort of issue updating that causes this as well? 😞
03-11-2016 23:50
03-11-2016 23:50
Same problem at my end. I was quite happy with fitbit till it stated to updated the tracker. I made the mistake of doing so and ended up withe exactly the same problem. Incidentally my wife has the saem problem. If there are going t o be som many bugs and quality of customer service below standard i am not convinced of an upgrade or ever buying one again. None of the solutions i have read on teh community pages are helping either. Anyone has an answer please do post
 Best Answer03-11-2016 23:51
03-11-2016 23:51
Same problem however on a Samsung S6
 Best Answer03-15-2016 21:52
03-15-2016 21:52
 Best Answer03-27-2016 13:20
03-27-2016 13:20
I have a fitbit charge hr and it froze up in the middle of the firmware update, every avenue has been tried multiple times, it still remains frozen, can't power off or reboot. I was wanting to know if you got the information about returning yours? Seems like it runs me in a circle when I try. If you can help I would be most greatfull. Thanks, Katarinaa52
 Best Answer03-27-2016 13:22
03-27-2016 13:22
 Best Answer03-28-2016 06:32
03-28-2016 06:32
 Best Answer03-28-2016 06:35
03-28-2016 06:35
 Best Answer03-28-2016 07:55
03-28-2016 07:55
I guess I got "lucky" since they will be replacing mine, only two months old. this will be costing fitbit corp if they are having to do large scale replacements. whoever approved that firmware update before it was unleashed on the world will probably be looking for a new job soon, if not out of work already
 Best Answer03-28-2016 10:07
03-28-2016 10:07
 Best Answer03-28-2016 10:10
03-28-2016 10:10
 Best Answer03-28-2016 17:19
03-28-2016 17:19
 Best Answer03-28-2016 22:55
03-28-2016 22:55
 Best Answer06-17-2020 16:16
06-17-2020 16:16
Yea mine did the same thing mine is a versa lite
 Best Answer09-06-2020 11:21
09-06-2020 11:21
I closed the Fitbit app, restarted the fit bit charge HR, turned Bluetooth off and back on my phone, turned the Fitbit app on, continued the update, and that worked 👍🏻
