11-09-2019
02:50
11:53
The usual things to try when you get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
Best AnswerI've done all those things several times. I never had problems with my Charge 2 syncing until the new dashboard software. Now it doesn't log my sleep a couple nights every week and it only missed one night every few nights before the upgrade. Nothing has changed, I wear the band the same it' not too loose or tight. I may have to look for a different fitness tracker.
