09-24-2017
13:21
20:15
09-24-2017
13:21
20:15
so when I mow the lawn (walk behind power mower) my Charge HR thinks I'm outdoor biking. (I get that, I'm moving through space but my arems aren't moving).
eg today I got 24 active minutes that way. But I'm going for steps not minutes and biking dispaly says I have 0 of 3001 steps attributed to this activity. So I edit the activity to mowing lawn. Now it says that 2441 of 3001 steps are attributed to that activity. Note these are not new steps. fitbit has sucked up steps from earlier in the day and assigned them to the time I was mowing the lawn even though it counted no steps during that interval. I think the 2441 steps should be added to my step count not just redistributed.
Is there a way to make this happen?
Moderator edit: updated subject for clarity and format.
10-05-2017 09:14
10-05-2017 09:14
Hope you are doing great and enjoying some healthy activities @ginbqik.
I know that this response is delayed, but I'll be glad to explain you this. Since the Fitbit tracker uses a 3-axis accelerometer to measure the movement, it's going to track a step whenever you arm is moving, even if this is only the vibration from the power mower.
My suggestion in this cases is to manually log a Driving activity using the time you were on the power mower so you can negate all the activity from that time.
Let me know if you have questions.
What's for breakfast?Check others recipes and share yours!
10-06-2017 15:07
10-06-2017 15:07
what you describe exactly the opposite of my problem
NOT SOLVED!
10-06-2017 15:09
10-06-2017 15:09
you changed the subject to reflect your MIS understaning of the problem and now probably no one who has a similar problem will be able to find my message
NOT SOLVED
07-14-2020 12:47
07-14-2020 12:47
I have the same issue. Strap it to your ankle???
07-18-2020 06:47
07-18-2020 06:47
Is there an answer for lawn mowing tracking steps during the time using a push mower?
Intense up and down hills and berms 1 acre, came up as around 2000 steps. It takes that amount to go down one side. Want to keep track of these steps as I mow these houses for customers.
09-10-2020 09:31
09-10-2020 09:31
My Fitbit is NOT counting my steps when I mow the lawn, it thinks I am riding a bicycle. It's cheating me out of thousands of steps that I want logged. How can I fix this? I don't even own a bicycle. It's time to do some mowing but I'd like to fix this problem first. I'm in a solo challenge that I need a lot of steps for each day; I'd like all of my steps to be counted.
09-10-2020 10:33
09-10-2020 10:33
So I did go out and mow; today it does seem to be counting steps and not recording a "workout." So for now, problem solved!
09-10-2020 17:08
