07-02-2016
21:13
20:15
07-02-2016
21:13
20:15
07-03-2016 17:00
07-03-2016 17:00
@Kunkel1 thanks for joining us here in the Community! That sounds very weird, indeed. In that case, I would recommend setting up your Charge HR as a replacement device without unpairing it by doing the following:
Let me know how it goes, I'll be around! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
07-03-2016 17:12
07-03-2016 17:12
Best Answer07-04-2016 14:43
07-04-2016 14:43
@Duchess46 thanks for joining us! Yikes, that doesn't sound too cheerful.
However, let me do my best to help you with this! Have you tried a restart already? If not I recommend doing the following:
Also, make sure that your Charge HR is up to date. Having the latest firmware can avoid any malfunctioning. Follow these instructions to update your tracker from a computer. Let me know how it goes! ![]()
Best Answer07-05-2016 07:07
07-05-2016 07:07
When I try to connect it to the phone, it gets to the last step, where is makes the connection after I enter the numbers, and it stays there forever. It does the same thing after restarting both devices. The only way it connects is after doing a factory reset on the fitbit.
Best Answer07-05-2016 16:27
07-05-2016 16:27
07-05-2016 16:28
07-05-2016 16:28
Best Answer07-06-2016 05:19
07-06-2016 05:19
Purchased my Charge HR in November, 2015. Similar problem but no luck with factory reset.
Hoping to try your suggestion but can't get past 1st step. Can't find Fitbit menu in upper left corner.
Problems:
battery draining
not syncing/pairing
wrong time
I have already sent email to Support this morning.
Any other suggestons would be appreciated. Need the HR to track my heart rate.
Best Answer07-06-2016 07:12
07-06-2016 07:12
when you refer to the Fitbit app dashboard, are you talking about on your phone, or on your computer? I am having the same problem, I cannot get my time to sync. Additionally, there are times I wake up in the morning and I already have in 2000+ steps. That has happened even when not wearing the fitbit after only having it for 2 months. It has caused me to give up on it for the last couple months, but I would like to wear it again.
07-06-2016 07:52
07-06-2016 07:52
Best Answer07-06-2016 16:01 - edited 07-08-2016 17:02
@Duchess46 thanks for the update! I'm sure your Charge HR is going to work excellent for you this time. Thanks for sharing what worked for you!
@Kunkel1, @deacon12, @teeth_13 welcome to the forums guys!
@deacon12 I believe that if you've tried with the factory reset without any luck then I recommend waiting for our Support Team's response.
@teeth_13 & @Kunkel1 I recommend a factory reset just like @Duchess46 suggested. If that doesn't work, please get back to me so we can analyze this further! Good luck and I'll be looking forward to your new comments. ![]()
07-06-2016 16:52
07-06-2016 16:52
07-07-2016 13:33
07-07-2016 13:33
Awesome, great suggestion @Duchess46! In that way you'll be able to start fresh and get your tracker working as good as new!
Happy stepping and I'm so glad to see helpful users like yourself in the Community! Keep up the great work. ![]()
07-17-2016 14:18
07-17-2016 14:18
Best Answer07-20-2016 16:38
07-20-2016 16:38
@teeth_13 welcome tot he forums! Yikes, I'm sorry to h ear about your buddy.
Let's try this:
If that doesn't do it then, I recommend contacting our Support Team for a second opinion. They definitely have the proper tools to take a deeper look into your tracker's behavior. When you contact them please let them know about the troubleshooting steps you've followed to fix this. By doing that you're helping them to provide you with a quick solution. Let me know how it goes! ![]()
Best Answer03-21-2019 19:58
03-21-2019 19:58
Had the same problem for the last couple of days. Fitbit ran out of charge during the night and wouldn't sync in the morning. Was afraid to take most of the reboot/resynch steps out of fear of losing my data. Just waited for the support team reply, trying to synch every other day. The reply never came but on the 7th or so try, a few days later, it synced! Waiting for a day or two might fix the issue on its own. At least it worked for me!
Best Answer04-08-2020 22:15
04-08-2020 22:15
Same here, I have the Fitbit versa though.
Best Answer04-09-2020 04:28
04-09-2020 04:28
Best Answer04-09-2020 05:02
04-09-2020 05:02
