10-25-2016
15:38
10:26
10-25-2016
15:38
10:26
10-26-2016 04:42 - edited 02-08-2024 06:14
It's nice to see you around the Community @Antebella, hope you're doing great! If your heart rate seems not to be accurate, I'd recommend taking a look at this post to improve its accuracy.
01-11-2018 12:29
01-11-2018 12:29
I found the same issue with my new Fitbit. The response does not address the issue. Did you find a reason? Is it a software bug?
03-07-2018 07:03
03-07-2018 07:03
Same issue here. Still looking for answers
03-07-2018 19:08
03-07-2018 19:08
I noticed that mine was registering my heart rate at 122 when I was folding laundry tonight. My heart rate is rarely that high so when it is I can feel it. I took my blood pressure with a cuff that also reads puse and it read 77. I think that there is something off.
03-08-2018 00:07
03-08-2018 00:07
Hi there!
This may happen if you have extrasystoles. Extrasystoles are a premature contraction of the heart (quite common, actually). The wristband might pick those falsley up as higher bpm.
03-08-2018 05:13
03-08-2018 05:13
Check this out: https://community.fitbit.com/t5/Charge-2/Charge-2-Inaccurately-high-heartrate-Hack-fix-that-works/m-.... It is working so far for me.
09-22-2018 10:46
09-22-2018 10:46
I also have a fitbit 2 charge my heart rate says 123 but taking it on my blood pressure machine at same time says 78
and it does this alot
i heard wrist ones are not as accuritbut that’s a big jump
02-09-2019 06:17
02-09-2019 06:17
You can look at all the posts regarding Fitbit you like and you still have a very unreliable heart rate monitor. You keep fobbing people off on this issue and are currently been sued for your inaccurate product. I have a fitbit charge and its the biggest waste of £200 ever. When you know its wrong either admit it or shut up about it.
