07-31-2019
20:12
13:57
07-31-2019
20:12
13:57
I want to use both of my Charge 2's on the same account how do you do this
07-31-2019 20:23
07-31-2019 20:23
You can have two different styles on one account, but you can't have two of the same style. If you really want to do this, you'd have to swap out which Charge 2 you're using. Sync and log out of Device #1, move it out of range of Device #2 and set up Device #2 as a new device on an existing account. Swap as often as you like, but since they are the same style, it seems to be a lot of work to swap out if you do it frequently.
07-31-2019 20:25 - edited 07-31-2019 20:29
Same as @Odyssey13 got posted first while I was still answering.
If you want to use them both for the same person, the only way would be to sync with the one you were wearing, then set up the other one as a replacement device, and go through that every time you switch.
If you mean for 2 different people, you cannot have 2 people on one account.
