03-10-2019
19:47
11:22
03-10-2019
19:47
11:22
My grandson borrowed my Fitbit Charge 3 yesterday and now the screen shows very faintly, is there some way of brightening the screen?
03-10-2019 20:04
03-10-2019 20:04
From clock face, swipe left until get to 'Settings'; tap that; at the top is 'Brightness': dim, normal, or auto. I use auto to have it adjust with light sensor.
03-10-2019 20:04
03-10-2019 20:04
03-10-2019
20:11
07:26
AlejandraFitbit
03-10-2019
20:11
07:26
AlejandraFitbit
Excellent! Worked like a charm! Thank you!
Moderator edit: format
03-11-2019
07:30
11:45
03-11-2019
07:30
11:45
A warm welcome to the Community @57gal and @JohnnyRow thanks for the input.
I was able to see here that our friend @JohnnyRow answered your question about how to adjust the brightness of your tracker.
If this answer was the one you were looking for, I recommend marking the answer given as a solution. By doing this, other users with the same question will be able to find a faster response.
Let me know if you need anything else.
06-20-2019 04:25
06-20-2019 04:25
I have the brightness on the highest level but it is impossible to see the screen when outside. Is there something that can be done to correct this?
06-20-2019 14:07
06-20-2019 14:07
Think I saw auto but it was too faint now just total black screen
06-20-2019 15:19 - edited 06-20-2019 15:23
I have the exact same problem. I hit the auto and my screen went blank.
06-20-2019 18:49
06-20-2019 18:49
06-25-2019 05:08
06-25-2019 05:08
I tried this. And now I have no dispay at all. Is there a way to reset my device? It’s been so dim I can’t see it most of the time. And now it doesn’t light up at all
07-17-2019 16:38
07-17-2019 16:38
I have set mine on both auto and normal but it is still i.possi le to read in the sunlight. Ha e to go under a tree to see it. Also the screen time is too short to try to squint at and than it goes out. Can screen time be increase lime the versa? I know it will impact battery life but its no good if I cant read it while on a walk. I ha e heart issues and I need to keep my heart rate under my peak.
07-17-2019 18:31
07-17-2019 18:31
07-18-2019 06:30
07-18-2019 06:30
Thanks Johnny. Worked a treat.
10-09-2020 16:34
10-09-2020 16:34
What if you cannot see it enough to find the screen you need to be on
02-03-2021 09:24
02-03-2021 09:24
This is my problem as well I cannot see my screen to adjust the settings. My charge three is fully charged any help is appreciated
02-07-2021 09:02
02-07-2021 09:02
I did finally get to settings only by guessing. The problem is when it has gone to dim (on its own), you can barely read any of the screens!! There should be a better way to brighten by way of your Smartphone.
09-10-2022 11:32
09-10-2022 11:32
So then it is finished? I cannot see my screen at all
10-13-2022 00:12
10-13-2022 00:12
A bright screen can suck a lot of energy out of a touchscreen Fitbit (such as a Versa, Charge 3, or Ionic). On your device's screen, swipe left until you find “Settings.” Select that. Scroll to “Brightness.” Tap that button to cycle through brightness levels.
Regards,
Will
01-05-2023 08:45
01-05-2023 08:45
Yay! Very simple, but works! Thank you!!
