12-18-2018
08:34
14:31
12-18-2018
08:34
14:31
No Fitbit Charge 3 software for iMac. Only 2, android phone ... not able to find in advance sleep setting to change to sensitivity .. as after 1 week I have had only 1 full information on my sleep pattern. In the dashboard here was able to change.
QUESTION IS: changing here on the dashboard .. update my Fitbit to correct setting required.
Thank you for your time in this matter.
12-19-2018
03:21
03:51
12-19-2018
03:21
03:51
It's great to see you around @fabweb.
If you want to change your tracker's sensitivity, you need to do the following from your Dashboard:
I hope this helps, catch you later.
Best Answer12-19-2018 03:26
12-19-2018 03:26
thank you for your reply
i download for windows 10 and changed it there
it made no different ..my sleep pattern was recoreed from 05.38 am to 08.38 ..when i got up to go to toilet .... i am getting a bit fed up with this device ..everything workd greta except what i brought it for ..
i have shaved off hairs on arm , wearing high up , rebooted a number of times and i have had only 1 full set of data in 10 days for night sleep..DO YOU THINK I NEED TO RETURN IT #
12-20-2018
07:09
03:50
12-20-2018
07:09
03:50
Thanks for the update @fabweb and information.
If you are sleeping and wake up to the bathroom, your tracker will register that you are already awake since you actually wake up. If you don't want to see the time you were awake on your graph, you can always edit your sleep information by following the instructions provide in the help article How do I change my sleep history?.
Catch you later. ![]()
Best Answer01-12-2019 10:27
01-12-2019 10:27
I am having same problem with a new Fitbit Charge 3. It either doesn't record sleep or records only between 1 and 3 hours of it all satrting between 4am and 7am when I go to bed about midnight. Also have called tech support several times, about ready to return this to the store and get a different brand
01-14-2019 03:32
01-14-2019 03:32
i have been on to support for last month ... and am about to replace and see if that makes any difference although i tried my wifes ..it worked on her and her was the same on me xx
Best Answer05-21-2019 10:42
05-21-2019 10:42
I'm having the same issue. Worked fine in the beginning now it doesn't record my total sleep correctly.
Where you able to figure it out?
I reset my sensitivity to normal to see if that helps but I've only just done it so I'll have to see tonight.
05-25-2019 13:02
05-25-2019 13:02
I'd give anything to have the accuracy of my fitFit2 back. I'm a truck driver and this Charge 3 has me running marathons and never sleeping. WAY too sensitive and doesn't seem to be a real solution?
Best Answer12-07-2019 02:58
12-07-2019 02:58
There is no gear icon on today - so can't check or select sleep monitoring or sensitivity - PhilVN
12-07-2019 03:01
12-07-2019 03:01
There is no gear icon on dashboard or on Today - so can't check the settings or select sleep monitoring or sensitivity - my Charge 3 stopped sleep monitoring a week ago - can't get it to restart - PhilVN
06-14-2020 02:06
06-14-2020 02:06
I’ve had the same problem. Charge 3 and 4 cause headaches and heart palpitations due to the EMF radiation. I have a hypersensitivity to EMF radiation and for some reason Fitbit changed the EMF’s when the Charge 3 and Charge 4 were made. I’m returning the Charge 4 and fortunately I found another Charge 2 on Amazon. Scoop them up—-Fitbit stopped making the Charge 2. Big mistake.
