How do I change the activity to walk
ANSWERED
On the list of activities it shows r
RUN but not walk?
1 BEST ANSWER
Accepted Solutions
When on that screen you can scroll through to select it.
But if its what you use the most. Go to settings. Click on the device name. Scroll down to exerecise short cuts and move walk to the top. Then it will show first.
Community Council Member
Wendy | CA | Moto G6 Android
9 REPLIES 9
Walk is not an option  in my list on the versa how do i add it
Hey @MJB9, I hope you are doin' fine! If you are using the Fitbit app on an Android phone, for you to see "Walk" as an option on the Versa itself, you have to select this activity by using the Fitbit Dashboard on a computer. Following the instructions that @WendyB posted above, but clicking on "Edit" and then you'll see the different exercises that you can select, so select "Walk" and click on "Save" Then sync your Versa.
Hope this helps!
Heydy | Community Moderator, Fitbit
The step that was missing was you have to delete an activity in order to
add one
Once I figured that out, I was able to add walk and yoga
The screen should say that, and it doesn't.
~MJ
Thanks for your reply @MJB9! I do apologize. I forgot to add that important detail. You can only have up to 7 exercises shortcuts selected. Please feel free to keep me posted if you have further questions!
I'll be around!
How do you delete an activity and add walk? On Fitbit or on app?
Hello @Askalice, let me give you a warm welcome to the Community! If you'd like to add your walk to the Fitbit app once you've completed it, please follow these instructions:
  1. From the Fitbit app dashboard, tap the + icon > Track Exercise
  2. Tap Log.
  3. Tap a recent activity or search for an exercise type.
  4. Enter the activity details and tap Add.
Now, in order to add the "Walk" to the Charge 2, please follow the instructions that @WendyB posted above and keep in mind that you can only have up to 7 activities, so if it is necessary, you'd have to delete one of them.
Hope that helps!
On the app
Tap the picture of your versa at the top of the screen,
Go to exercise shortcut  ,
Swipe left to remove one of the activities,
Hit the plus sign top right to add a new one l
Hey @MJB9, hope you doing great! Thanks for sharing those tips. They will definitely help other users out with the same doubt.
Have a nice day!
