01-01-2020
12:23
15:40
01-01-2020
12:23
15:40
Can anyone tell me why my fitbit states it is 8am when it’s 8pm? Does it not have a 24 hour clock? The time is right just 12 hours out!!?? I’ve tried removing the auto time zone thing & then syncing it but its still 12 hours out? Confused!
01-03-2020 11:05
01-03-2020 11:05
Welcome to the Community, @Julia11 and @SteveH, thanks for the input.
I was able to see here that our friend @SteveH provided some instructions in order to change your clock format. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best Answer01-02-2020 01:32
01-02-2020 01:32
You can choose between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync your fitbit will be updated.
Best Answer01-03-2020 11:05
01-03-2020 11:05
