How do I change the clock format?
My Fitbit Charge 3 is only showing military time... How do I change it?
4 REPLIES 4
Hi @Jfloyd  Changing it is easy, but has to be done from the website dashboard, rather than the app. In the Dashboard tap on the Gear Wheel icon in the rop right corner and then select Settings. On the settings page scrolp down to Advanced Settings and select Clock Display Time and change it there. Then select Submit at the bottom of the page. Sync your tracker and all should be done!
Community Council Member
Helen | Western Australia
Welcome to the Community, @Jfloyd and @NellyG, thanks for the input.
I was able to see here that our friend @NellyG provided some instructions in order to change your clock format. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
Sadly, I’m a senior citizen and still can’t figure it out (what’s my “dashboard “?) Thank you, Nelly!
Sent from my iPhone
Sorry I wasnt clear enough (Im a senior cit too by the way 🤣)
Right at the top of all forum pages  are three links Help Dashboard and Store. Tap the Dashboard one to get to the dashboard page.
Here are a couple of screen shots to help
Where to find the Dashboard
 and the gear wheel icon in the next point
And please come back again if you are still stuck. 
