01-11-2020 04:12 - last edited on 09-24-2020 19:06 by
After initial set up, I can’t seem to find where to change locations for the weather feature. Anyone know where it is?
01-11-2020 11:13
01-11-2020 11:13
Under the Settings on Fitbit.com, click on Apps and then Weather.
Best Answer01-12-2020 06:19 - edited 01-12-2020 06:19
Hi there @CheryPask, welcome to the Community Forums.
As my friend @SunsetRunner mentioned, to set up the Weather app:
If the weather doesn't update, check the following settings:
If you change locations, sync your device to see your new location in the Weather app.
Let us know if you need further assistance.
