11-07-2018
12:00
15:03
11-07-2018
12:00
15:03
How do I increase my step goal? Tried in the app but struggling.
Thanks
11-07-2018 12:37
11-07-2018 12:37
Tap on the steps tile on the dashboard, then tap on the gear in the right corner. Then tap on the goal and a new window will pop up to let you change it.
11-07-2018 12:37
11-07-2018 12:37
11-08-2018
05:10
08:14
11-08-2018
05:10
08:14
It's great to see you around @amietempest and @SunsetRunner thanks for stopping by.
I am glad to see here that our friend replied your inquiry. If there is anything else we can do for you, do not hesitate to post it.
Happy stepping! ![]()
Best Answer05-23-2019 10:27
05-23-2019 10:27
I need help... I cannot seem to edit my steps goal (Charge 3) based on responses provided to other members. There is no gear icon on right corner of 'STEPS' tile and when I click the one located in bottom left section of tile, and click on it, it only mentions a removal of the tile itself. The 'SEE MORE' section (to the right) does not help either as there is no button to click on page shown in order to edit steps count. I have searched throughout my dashboard trying to locate a "GOALS" section to try and edit from there to no avail. What am I overseeing?
06-19-2019 12:53
06-19-2019 12:53
Hello! I was wondering if this solution is still accurate. I went to my dashboard and tried clicking the steps tile, but the only thing I can seem to do when clicking the settings bar for the steps tile is remove it. Is this something I need the paid service for?
03-23-2020 23:37
03-23-2020 23:37
Did you get a fix for this? I have the same problem. Everywhere I can see my step goal I update it but it won’t save. Argh!!!!
06-11-2022 13:18
06-11-2022 13:18
This is exactly the same for me. It's really annoying. Has anyone found a fix?
