05-09-2023
17:51
06:52
05-09-2023
17:51
06:52
Is there a way to specifically search for charge 3 watch faces instead of having to go thru 300 watch faces only to not find any so far for my watch?
05-10-2023 02:13
05-10-2023 02:13
Hi, @lynchknot @please go to your Fitbit app and from the opening, Today, screen click on the person photo/icon top left. On the next screen click on your Charge 3. And then choose Gallery and then clock faces. You will see the faces available for your Fitbit.
05-11-2023 12:54
05-11-2023 12:54
Thanks for that. Unfortunatly the screen is so dim under normal settings its almost usless
Best Answer05-11-2023 14:48
05-11-2023 14:48
Hi, @lynchknot , your question did not mention anything about about the screen being dim, and the suggestion I sent has nothing to do with the watch face dimness, because if you had looked at the instructions you would see that what I suggested is entirely done in the app so the screen dimness is not relevant.
If your problem is a dim screen rather than how to find clock faces, then that is a different question altogether!
My experience is that this issue (dim screen) may be due to the age of your device, but it is worth going into a very dark room and checking the settings area on the Fitbit and making sure your Charge 3 screen settings are set to “normal”. That’s as bright as it comes.
