01-29-2022
22:04
15:43
01-29-2022
22:04
15:43
Battery does not want to charge. Was suggested I reboot. How do I do this?
01-30-2022 00:26
01-30-2022 00:26
While trying to charge, press and hold the button on the tracker for 8 seconds until you see a smile icon
Help article: How do I restart my tracker?
01-30-2022 00:26
01-30-2022 00:26
07-07-2023 09:29
07-07-2023 09:29
How can you press and hold the button when the clamps cover the side when charging 🤔
Best Answer07-07-2023 17:59
07-07-2023 17:59
If the clamp is covering the button, then the clamp is either on backwards, or it's not the correct charger. The oval cutout in the clamp should be on the side with the button. When it's placed properly, the button is in the center of the cutout.
