12-08-2017
20:12
18:54
12-08-2017
20:12
18:54
At one point I figured out how to set a reminder for my Fitbit to vibrate at preset times. I can't find it again and need to change it. Can anyone direct me?
Go to your Dashboard and click on the Charge 2 and a new menu will open and you can add/ or change alarms or change reminders to move.
Best AnswerSilent Alarms. I just didn't remember what they were called. Even more helpful would have been to add click on settings sprocket icon and click Charge 2 at the top. Thank you very much, this was very helpful!
Best AnswerThank you.. This is the best feature but they don't make it easy to find. I always forget where alarms are.. Thank you again!
Best AnswerThis is the dashboard @KennaB tap where I circled. Then tap the icon of your tracker. Then see page 21 of the user manual. Or go to fitbits interactive help guide.
