10-03-2021
13:27
15:19
CindyMFitbit
10-03-2021
13:27
15:19
CindyMFitbit
I have had to order a new charger for my charge 3 if hasn't been in operation for 7 weeks
I cannot get my app to display information on number of steps and sleep details
10-03-2021 15:22
10-03-2021 15:22
Welcome! It's great to see you around @Mcdonnell.
Thanks for the details shared in your post. If you received the new charging cable and you already charged the Charge 3, I recommend doing the following:
Hope this helps.
10-03-2021 23:39
10-03-2021 23:39
10-04-2021 11:36
10-04-2021 11:36
Thanks for your response @Mcdonnell.
Please note that when you try to set up the the Charge 3 and your phone is able to find it, you will see the code to pair the device, it should be a new 4 digit code displayed on the Charge 3. As you have mentioned that the system is not allowing you to reset the code, please confirm, are you getting an error message? is your phone able to find the tracker?
Catch you later.
