04-13-2019 07:12 - last edited on 11-17-2020 11:10 by MatthewFitbit
I just received a new replacement for my Fitbit 3. How do I set it up? I already have the Fitbit app.
04-13-2019 07:19
04-13-2019 07:19
You have to remove the old fitbit 3 from the app, then set the new one up like you did the old one.
04-13-2019 07:19
04-13-2019 07:19
04-14-2019 07:00
04-14-2019 07:00
It's great to see you around @JPKBrawn3 and @vikvac49 thanks for the input.
I would like to know if you keep having issues pairing your replacement Charge 3? If so, I recommend taking a look at the help article How do I set up my Fitbit device? and follow the instructions provided there.
Let me know how it goes. 😉
04-14-2019 08:40
04-14-2019 08:40
I discovered that the Charge 3 can only be setup using the mobile app, according to the Fitbit app's setup screen (after 2 hours of trying on my computer and online, and searching the help sections of fitbit.com). Also, I needed to uninstall the app from my phone and reinstall it before it would work; otherwise bluetooth would not connect.
When I received the replacement in the mail, there were no instructions at all. I found that the strap is very easy to remove and connect to the new head. Would have been nice to include a few simple bullet points to reduce the frustration. Was about 10 minutes away from giving up and buying an Apple watch.
04-15-2019 04:03
04-15-2019 04:03
Thanks for getting back and for letting us know that your tracker is now paired @DianneMR. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! 🙂
04-16-2019 05:52
04-16-2019 05:52
05-01-2019 23:50
05-01-2019 23:50
How do I remove the Fitbit one so that I can setup my new charge 3
09-15-2019 17:06
09-15-2019 17:06
I have a Charge 3 replacement and I can't connect. All the setup links are useless.
I can sign into my account but that's about it.
So do I need to uninstall on my Android and start fresh?
09-15-2019 17:09
09-15-2019 17:09
Too bad Fitbit doesn't explain that on their setup link.
09-28-2019 08:19
09-28-2019 08:19
How do I remove the old fit bit from my app to install my replacement fit bit charge 3?
01-07-2020 17:31
01-07-2020 17:31
It's ridiculously hard to get correct instructions for replacing an old Fitbit Flex with a Fitbit Charge 3 in your Fitbit account. It shouldn't be this hard!!
01-08-2020 10:37
01-08-2020 10:37
Am using a Fitbit 2 have been given a used fitbit3 how do I change over to the 3
01-10-2020 14:28
01-10-2020 14:28
new fitbit charge 3 not syncing. I already removed my charge 2. I need specific instructions.
I don't have any original instructions
01-17-2020 19:45
01-17-2020 19:45
Ok this is what I did and it worked easily.
Go onto a PC and log in to your Fitbit account. Click on the "watch" icon in the top right hand corner and remove the old device from your account.
Uninstall the Fitbit app from your mobile phone/device and reinstall the app. When you start the app you can log in to your account and when you go to your profile, it gives the option to set up a new device. The phone/app will then give you instructions to follow to set it up. This involves connecting the new unit to your PC with the charging cable and locating the new unit via bluetooth and inputting a code shown on the new tracker to connect it to your account. My Charge 3 then needed an update which took a little while to do....After the update, you should be able to set up all of your preferences via the app.
These instructions should also work if you need to change from a Charge 2 to 3, or any Fitbit device.
01-19-2020 11:56
01-19-2020 11:56
After unsuccessfully following most of the comments and/or answers for addressing a Charge 3 not syncing with the Fitbit app, this worked for me.
Instead of trying to sync your Charge 3 to your mobile phone Fitbit app, try searching and pairing this device with the mobile phone's settings. Go to settings and click on "connected devices bluetooth." Then click on the found device Charge 3 to be paired and synced. A four digit number will occur on your fitbit. Type this number on your phone screen when prompted. Sync was accomplished.
01-19-2020 12:28
01-19-2020 12:28
01-19-2020 13:13
01-19-2020 13:13
Just remove the original charge 3 unit from the connected devices in phone settings. Then setup the replacement device as originally suggested.
03-29-2020 11:50
03-29-2020 11:50
how can i set up and replace my charge 3 with a new charge 3
03-29-2020 16:46
03-29-2020 16:46
Follow the instructions above....it should work but you can always ask specific questions if you are having problems
05-04-2020 13:41
05-04-2020 13:41
First, I uninstalled the app on my Android phone. Turned off my phone and turned it back on. Reinstalled the Fitbit app. I am not sure this was necessary, but that was the advice I was reading on this community page.
When I signed in to the app on my phone, it still had the old Charge 3 on there. So I went to my profile and found the listed devices that were attached. There was a small trash can to the right of the title of my Charge 3. I deleted that one. Then selected, add a device.
It is going through the set up now. You have to have your new Charge 3 on the charger while doing the setup.
This worked for me, I hope it works for you.
