05-20-2020
14:06
16:20
05-20-2020
14:06
16:20
My timer will not stop running. I'm not sure how to turn it off.
05-21-2020 06:26
05-21-2020 06:26
It's great to see you here, @Jojo48.
If you want to stop your timer, make sure to be doing the following:
Let me know if you need anything else. 🙂
04-15-2021 19:15
04-15-2021 19:15
Is there anywhere there are images of what the icons look like? All I see are numbers (amount of time) and a stop watch . Nothing that remotely looks like a play or stop icon
05-05-2021 00:35
05-05-2021 07:12
05-05-2021 07:12
Hello @Bdoan, @RJoyBeall. Welcome to the community forums!
For more information, I recommend visiting the following link: How do I set a timer or use the stopwatch on my Fitbit device? You can also visit the following link to get more details about how to navigate your Charge 4: How do I navigate my Fitbit device?
The timers app appears with an icon described on the page 30, from the Charge 4 manual.
Hope this helps.
06-03-2021 11:44
06-03-2021 11:44
Agreed, there is nothing even remotely like an icon. Not sure how you figured it out, I put it on my charger and did the reset. This should have been a lot easier.
07-07-2021 06:53
07-07-2021 06:53
Sorry, not helpful. I turned on the timer somehow and need to know how to turn it OFF please. The timer just keeps on going and tapping the screen on the fitbit charge 4 just scrolls thru the screens.
09-05-2021 16:57
09-05-2021 16:57
Pause the timer then swipe from bottom to top. A new screen appears and you can rest the timer to zero.
09-05-2021 16:59
09-05-2021 16:59
go to the timer count screen and press pause. Then scroll from bottom to top for next screen. You can now turn off the timer and reset to zero.
02-22-2022 06:48
02-22-2022 06:48
Followed above. But the reset never lets you get back down to "0". You can input 0 minutes, but not get out of the seconds screen and there is no "0". Always stuck with at least 0.01 seconds. Feature I always used on my Charge 2. Reset should take you to 0. Will go back and read other links.
02-22-2022 06:48
02-22-2022 06:48
NO - You can never get to "0" seconds. Stuck at 0.01 seconds.
