05-04-2017
14:00
20:15
05-04-2017
14:00
20:15
I have looked and looked. I have an Ipad and an android. I was reading where it says go to your dashboard, then the pink see more button. I have a charge HR, this should not be this hard!
Moderator edit: Title for clarity and punctuation
03-22-2019 13:23
03-22-2019 13:23
05-04-2017
16:12
07:01
05-04-2017
16:12
07:01
@55Bar59 I suggest checking out the information on how to manually add steps across all platforms here.
Hope this helps!
Actively managing your weight? Find accountability buddies on the Manage Weight board
05-08-2017 17:05
05-08-2017 17:05
I'm not finding a way to simply add steps. I've been home today, no defined time for exercise, just know I did at least 1000 steps between noon and 7 PM. ???
05-12-2017 15:11
05-12-2017 15:11
@55Bar59 check out my tips on this post here.
03-22-2019 13:23
03-22-2019 13:23
03-22-2019 13:25
03-22-2019 13:25
I have to put in when I start, the duration, the pace the calories and distance. All I want to do is put in like 8,500 steps?
03-23-2019 07:50
03-23-2019 07:50
You might not know this, but even when you enter the steps manually, they don't get counted for your lifetime totals. They do count for your weekly progress. There is a suggestion to include them in the life time totals somewhere on a Fitbit page. You might consider voting for that suggestion, if you think it would be nice to have. I was a little bummed because my Fitbit died and I lost a couple weeks from my totals.
