How to change time
change time on fitbit secure
3 REPLIES 3
update time on Fitbit
Hi @dianeosni   the time is set to the device you use to sync. You may need to sync a few times. Be sure your phone or computer has the correct time zone on it, too.
Stepping in the U.S.A. since September 2013. Android 14
Hi @dianeosni, welcome to the Community Forums!
Just as our friend @Odyssey13 shared with you, Fitbit devices use your mobile device information to display the time with the syncing process, therefore, by simply syncing your Fitbit it should display the time that's configured on your mobile device.
However, if syncing doesn't work, you can update the time zone setting in your Personal Settings. For step-by-step instructions, please see our help article: How do I change the time on my Fitbit device? and let me know how it goes.
Keep me posted.
