10-16-2020
03:32
09:53
AndreaFitbit
10-16-2020
03:32
09:53
AndreaFitbit
So, my Charge 3 band broke and I purchased a new band. To my chagrin, when I removed the old band the one of the band release tabs stuck in and did not spring back out. Unfortunately, the new band would not stay attached.
There seems to be two issues when discussing bands. 1) the band breaks 2) the band will not stay attached.
Either issue can be solved if you are still under warranty by getting either a replacement band or a replacement unit. Note: If your band will not stay attached a new band WILL NOT fix this. It appears fitbit is more than willing to send you a new band in either case. But a new band will not fix a band that will not stay attached.
FIX: I removed my new band and found that the unit was very dirty and gummed up with who knows what. I took a can of WD-40 and sprayed both ends, where the band attaches, with as much pressure as I could. I used a small brush and a very small flat blade screw drive to remove all the debris. I let the WD-40 soak overnight and hit it again. The spring action on the locking tabs returned and the band has stayed on ever since.
Give it a try. The WD-40 did not do any harm and what do you have to loose.
Moderator edit: format.
10-01-2021 14:48
10-01-2021 14:48
Extremely awesome advice! Ahh WD40…who’d uh thunkit…not Eye.
“Free Of Charge 3 Free bCuz Caz”
Appreciate this
quick fix
It
saved me bits of Fits,
and that ain’t just it,
won’t have ta’ take a hit n’
have
go n’ got’
another
mother lovin’ Fitbit.
Aww Sh%+!
-jL
10-02-2021 09:55
10-02-2021 09:55
Welcome to the Fitbit Communtity, @Caz1592, @josephxploseph. Thanks for sharing your advise to fix bands.
This could help other users and already helped @josephxploseph.
Thank you for visiting our forums.
03-21-2022 18:57
03-21-2022 18:57
Yes the issue is actually quite simple.
As dirt builds up the clasping mechanism (black t-shaped piece) can get stuck half way into position.
I just used a paper clip to clean out the gunk and the push the clasping mechanism into place (ie fully aligned with the base of the device).
Then the band connected no problem.
03-22-2022 09:41 - edited 03-22-2022 09:41
Welcome to the Fitbit Community, @Sb1616. Thank you for the amazing advise you just shared with us. This will be useful for other users for sure.
I'd like to invite you to visit our Discussions boards where you can share your experiences, meet people and create new topics.
Have a nice day!
03-24-2022 06:29
03-24-2022 06:29
03-24-2022 07:47
03-24-2022 07:47
Thanks for getting back to us and for letting us know about the steps you followed in order to fix your band @josephxploseph.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Have a nice day.
