01-30-2017
15:30
10:13
01-30-2017
15:30
10:13
You have to set a goal to move or so many hours get that goal you will get that game it is called the fitbit flight. That is how you get the Fitbit Flight game.
01-30-2017 15:43
01-30-2017 15:43
Hi @gmorrell,
Fitbit Flight triggers on your Charge 2 if you've:
1. Updated to firmware version 22.48.14. Click here for instructions on how to update if you haven't already.
2. And hit all of your activity goals and Reminders to Move for the day before midnight.
Hope this provides some clarification.
02-21-2017 09:33
02-21-2017 09:33
It won't go away, any ideas?
02-21-2017 10:05
02-22-2017 05:24
02-22-2017 05:24
Cute idea but now it won't go away so I can't use my Fitbit. I have a device that only plays this simple game now
02-22-2017 06:44
02-22-2017 06:44
Press and hold the button until it turns off, same as to do notifications on and off. That's how I got it to go away.
02-27-2017 20:09
02-27-2017 20:09
@HeatherSweet wrote:Cute idea but now it won't go away so I can't use my Fitbit. I have a device that only plays this simple game now
Your saying there is no clock, won't tell you the time, no exercise function, it doesn't count your steps?
Why do some say it is just a menu option that can be easily skipped over?
02-28-2017
05:15
09:03
AlvaroFitbit
02-28-2017
05:15
09:03
AlvaroFitbit
They are correct. Half asleep operator error on my part. My apologies.
Moderator edit: removed personal information
Best Answer04-28-2017 04:16
04-28-2017 04:16
Thank you
Best Answer06-29-2017 21:56
06-29-2017 21:56
When you finish the game hold the button on the side for a long time and then you should be able to use your fitbit normally but the icon will remain until midnight. Hope this helps
07-16-2017 09:32 - edited 07-16-2017 09:33
@21roca I hope you're doing well! Thank you for sharing that bit of information as I am sure it will help other members in the same situation. For anyone else who would like to know how to get the game you need to reach your daily goals but there are to options:
If Reminders to Move is on, the game appears if:
All daily goals are completed: Steps, Distance, Calories, Floors, Active Minutes, and Reminders To Move for each hour.
If Reminders to Move is off, the game appears if:
All daily goals are completed: Steps, Distance, Calories, Floors, and Active Minutes.
In addition,the main goal must be met 3 times. For example, if your Main Goals is 1,000 steps per day, you must acquire 3,000 steps to unlock the game.
Also, and this has already been mentioned, your tracker should have the latest firmware.
Let me know how it goes!
08-07-2017 19:26 - edited 08-07-2017 19:27
"In addition,the main goal must be met 3 times. For example, if your Main Goals is 1,000 steps per day, you must acquire 3,000 steps to unlock the game"
That would mean I would need 33000 steps, and that can't be right! But I'll test your theory and set my main goal of steps down to 3000 just to test that theory. I hit all my goals of Steps, Floors, Distance, Calories, Hours to move etc during the week every day. I've never gotten it on my FitBit.
Best Answer08-21-2017 17:10
08-21-2017 17:10
How do you play the game once it appears on your Fitbit? Just tap on the screen?
Best Answer08-22-2017 03:21
08-22-2017 03:21
You start ot like any other feature by holding in the button.
Then tap the button to control the game.
10-24-2017 14:11
10-24-2017 14:11
Is there anyway to get it permentaly on your Fitbit charge 2
10-24-2017 22:38 - edited 11-23-2017 10:54
What is the reward in that?
Best Answer11-23-2017 00:41
11-23-2017 00:41
I have completed all my activity goals before midnight but the game still hasn’t come up
Best Answer11-23-2017 10:55
11-23-2017 10:55
All of your tiles need to be green and on your tracker every active hour needs to have been hit.
Best Answer12-17-2017 10:32
12-17-2017 10:32
Can u get the game on the surge
Best Answer05-05-2018 20:59
05-05-2018 20:59
Just hold down the side button for 3 seconds, just like you do to turn off notifications 🙂
