10-27-2016
16:01
10:26
10-27-2016
16:01
10:26
Best AnswerIf your taking larger steps then what Fitbit thinks your taking, then fitbit will report a low distance.
Say fitbit thinks your stride is 3 feet and your really doing 3.5 feet. So in 100 step you will have gone 450 feet, but Fitbit will calculate it as 300 - Steps times stride = distance.
As for step count accuracy simply start up the tracking mode and start walking while counting every left or right step. Count off 250 steps and the Charge2 should report about 500 steps.
Now if the Gps is still enabled, I don't know what tracking mode was used, but since your standing still this could affect the reported distance.
I just walked 6 miles on the treadmill and my Fitbit shows 4 miles. Happens every time, every day. I have measured my stride length and adjusted it on Fitbit with no change. I don't hold on to the bars and make sure my movement is the same as off the treadmill. Still haven't figured out the problem. Frustrated!
