02-26-2019
10:35
11:25
02-26-2019
10:35
11:25
I have a Charge 3 and until this morning, the weather location always displayed correctly. I have changed nothing on the App and all of a sudden, it is displaying the weather for Randlett, UT. instead of Surprise, AZ. where I live. I have never even heard of Randlett let alone been there. I have an Android phone, Android version 5.1. Any help is appreciated!
02-26-2019 16:22
02-26-2019 16:22
@jmahoney, actually, you can! There's a wireless reboot option. On your tracker, swipe 3 times to the left, tap on Settings, swipe up till you get to About - tap on it, swipe up till you get to Reboot Device.
02-26-2019 13:19
02-26-2019 13:19
@jmahoney, welcome to the forum! May I ask you to check your account settings in Fitbit app? Go to the rectangular icon in the top right corner (account settings) and tap on it. Then scroll down to Settings section - find Advanced Settings and tap on it. Do you have Automatic time zone and location enabled there?
Now, in Fitbit app tap on Charge 3 icon, tap on Apps tile, tap on Weather -> Settings. You can see an option to edit list of cities. Current Location option will read location from your phone. If needed, you can manually add other locations.
Sync with your tracker and check whether the issue is solved.
If it's all set correctly and your phone location is turned on and is working properly, but you still see incorrect location in weather app, you may need to clear your Fitbit app cache (your data will NOT be impacted). Close Fitbit app then go to your phone settings, find apps -> Fitbit -> Storage -> Clear Cache. Open Fitbit app and sync it with your tracker. Check the weather app location
02-26-2019 14:07
02-26-2019 14:07
Did everything you just suggested and still says Randlett. Only thing I can think of left to do is reset the Fitbit itself, but can't do that until I'm home this evening.
02-26-2019 16:22
02-26-2019 16:22
02-27-2019 06:06
02-27-2019 06:06
Still no success. I have done everything I can think of and everything you have suggested, including uninstalling and reinstalling the App. It still tells me the weather in Randlett.
02-27-2019 09:54
02-27-2019 09:54
@jmahoney, this is just odd.... and your tracker is syncing successfully with the phone, right? Location on the phone is also correct? If this is the case, then something might be 'stuck' on a tracker...
Lets try couple other options... Can you, please, change clock face on your tracker to any other one (then you can revert it back to your preferred option)? It forces reboot and sync... I wonder if it would help to refresh weather location... You may also attempt several restarts (with or without cable) and try a long restart.
Long restart:
Please, let us know how it goes!
02-27-2019 09:57
02-27-2019 09:57
Literally just before I got this message, I just happened to check again and it is nor suddenly displaying correctly. Not sure what did the trick, but thanks for your help!
02-27-2019 10:00
02-27-2019 10:00
@jmahoney, thank you for the good news! It was just thinking a bit too long Glad it's working correctly for you now!!!
04-21-2019 11:37
04-21-2019 11:37
Hi Rise and Shine,
I followed the steps that you suggested and still no luck. I am in California. I was in Hilo 5 days ago and it is still showing Hilo as my location.
Any other ideas on how to fix it?
Thank you
04-21-2019 22:43
04-21-2019 22:43
@ShannaS, I don't think I know any other 'tricks' - everything is outlined above. For a successful location identification you just need the following:
1. Ensure Location is set to automatic in Fitbit app
2. Charge 3 is syncing successfully with your phone.
If your phone is showing correct location, but Fitbit does not - there could be some syncing issues.
Actually, one 'trick' you may want to try.... if you use Android phone, you can clear Fitbit app cache to eliminate the possibility that old location is 'stuck' in app cache (you can do it through phone settings=> apps => Fitbit app=> Storage=> Clear cache).
Best of luck!
04-22-2019
08:02
08:38
04-22-2019
08:02
08:38
Hey @ShannaS, it's great to see you around and @RiseAndShine thanks for the input.
I was able to see here that our friend @RiseAndShine provided some instructions in order to fix this weather issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 😊
06-17-2020 04:48
06-17-2020 04:48
I have tried everything to make it show my current location but it still says in I’m Sweden, which I haven’t been in 5 months. This reset thing doesn’t work.
