01-09-2023
12:35
15:48
LucioFitbit
01-09-2023
12:35
15:48
LucioFitbit
The main activity (core stats) tile on the Dashboard does not show up. I only see a spinning wheel. In the Android app the data are all available, but not on the Dashboard on my PC.
There is a related topic (Core Stats Not Loading On Dashboard) but that does not contain an answer!!
01-18-2023
15:55
08:39
01-18-2023
15:55
08:39
Hi there @johanstaal. Welcome to Community Forums.
Thank you for sharing your experience. I'd recommend you force sync, then refresh the screen and check if it loads.
Also you can click on the dashboard settings and see if you can add it from the list of tiles.
And check these articles, How do I use the Fitbit app? and How do I manage my Fitbit profile?.
