07-21-2019
13:32
14:11
07-21-2019
13:32
14:11
On the occasion I choose to re-log my sleep manually and I do so in segments of say, 3-4 hours, I have found that either the one before or after or both will show a slightly reduced hours of sleep. It will still display the start and end times as entered, but the sleep graph itself and the total hours asleep will be shortened on one end or the other.
If this is a sleep stages either before or after a simplified details, then it’s easily corrected by going back after done with the simplified and re-saving the stages data. However if it happens to be two segments that show sleep stages, this does not work. Why does it do this way anyway? I can’t think of a reason that makes sense. My guess is that it’s an overlooked and underreported flaw. Any helpful hints would be appreciated. Thank you!
Hi @julesjmj thanks for bringing this to my attention, it's nice to see you again participating here in the Community Forums. Let me give you a hand with this situation.
First, I appreciate all the information and details that were shared in your post, the details provided were really helpful for me to fully understand your concern, certainly this is not a common situation but I'm glad to be aware of it. To better assist you with this, can you please let me know if you're using a mobile device to check this information or Fitbit.com dashboard? Either way, which specific device platform and brand you're using? When was the first time you noticed this and how many times was experienced since then? If possible, can you please provide me with a screenshot of this situation? You can refer to this post to do so. Also, in the meantime I receive your answers, please log out and log in from your Fitbit account.
I'll be looking to your reply. Let me know if you have any additional questions.
