09-28-2020
04:00
10:32
09-28-2020
04:00
10:32
Hi all. 'Track Mindfulness' has appeared on my phone dashboard. I don't want it! Can I delete it or at least move it to the bottom of the display? Thanks
09-28-2020 06:17
09-28-2020 06:17
On Android, if you long press the tile, and 'X' will appear next to the tile, allowing you to remove or move it. There should also be an 'Edit' button at the top of the screen, tapping this will allow you to do the sane. Click 'Done' to apply the change.
Tiles that are not displayed appear at the bottom of the screen (scroll down) and can be added back in if you change your mind later.
09-28-2020 07:05
09-28-2020 07:05
Thanks DavidNS. I thought I’d tried long press but I tried again and it worked.
Best Answer10-03-2020 07:52
10-03-2020 07:52
I have an iPhone and would LOVE to get rid of this new “mindfulness” feature, but I can’t seem to delete it from my dashboard (holding it down to wait for a delete option doesn’t work). I wish they wouldn’t force new, unwanted features on users.
Best Answer10-04-2020 00:41
10-04-2020 00:41
Great news! Latest update for Fitbit includes an “Edit” button in the upper, right-hand corner. Click that, then you’ll see a little “X” appear next to each section on your dashboard; and you can delete whichever features you do not want to see on your dashboard. Bye-bye mindfulness! :))
10-04-2020 01:15
10-04-2020 01:15
Thanks. All sorted.
