01-05-2017
05:59
10:13
01-05-2017
05:59
10:13
Is there a way to increase the sensitivity of the Charge2 to wrist movement to insure the display activates consistently? I wear the device all day and also use it as a watch. There are many times when a natural movement of my wrist to see the time does not activate the display.
01-06-2017 12:18
01-06-2017 12:18
Hmmmm... this is very strange @StanTheMan. I'd recommend restarting your tracker at leas 3 times in a row by doing these steps:
Let me know if this works! Welcome, BTW! ![]()
01-06-2017 18:56
01-06-2017 18:56
Mine doesn't show when I turn my wrist either. I just did the restart 3 times in a row and I still have to push the button to see it. Any other suggestions?
01-06-2017 19:19
01-06-2017 19:19
@debidew, have you verified that you have Quick View enabled in your app Device settings? If not, enable it, and resync the tracker. Then try turning on the display by turning your wrist towards you.
01-06-2017 22:09
01-06-2017 22:09
Thanks. I had the same problem and setting the quick view to on activated the screen when my wrist is moved.
Best Answer01-07-2017 06:48
01-07-2017 06:48
Best Answer01-07-2017 06:51
01-07-2017 06:51
You are welcome, @debidew! I'm glad you got it going!
Best Answer01-07-2017 16:11
01-07-2017 16:11
Ok, I restarted the device 4 times. Since this is an intermittent issue, it will take a day or two of normal wear to see if it's resolved. Question: why do I have to reset at least 3 times?
Best Answer01-07-2017 16:14
01-07-2017 16:14
Good point, but unfortunately quick view has always been enabled for me. Really seems like a sensitivity issue. Sometimes I need to forcefully "snap" my wrist to get the display to activate. Most times, works fine.
Best Answer01-07-2017 16:15
01-07-2017 16:15
@StanTheMan wrote:Question: why do I have to reset at least 3 times?
You don't "have to", but many people have found that it clears out everything and makes sure the tracker gets a good clean start. One restart often does not do that.
Best Answer01-07-2017 16:26
01-07-2017 16:26
Thanks USAF-Larry. I hope it works, but as an engineer, needing to restart 3 times to insure the device really resets is a bit troubling...
Best Answer01-07-2017 16:31
01-07-2017 16:31
I know, @StanTheMan, I'm an electronics engineer, too. But, have you ever worked with Windows? Ctrl-Alt-Del is the answer....
Best Answer01-07-2017 16:39
01-07-2017 16:39
LOL. Amen.
Best Answer01-08-2017 14:12
01-08-2017 14:12
Resetting the Charge 2 didn't help, but I think I figured out what the issue is. The screen is turned on with the Quick View feature. It seems that for this feature to work, the Charge 2 has to be in a certain starting position and then rotated. Correct operation seems to be sensitive to this expected starting position. It does NOT seem to be a sensitivity issue (requiring a hard wrist "snap" to activate).
Some suggestions for Fitbit:
1. Provide users with the detail of how best to orient the Charge2 and then rotate to activate the screen.
2. Provide an "Always On" display option at a lower brightness to eliminate need for Quick View while not draining the battery too badly.
05-12-2019 05:21
05-12-2019 05:21
I love my Fitbit -just received a new band for the Alta but the display is not happening as it should, I googled help and it recorded some steps but still not displaying -the battery is fully charged
