10-21-2022
10:54
08:13
AndreaFitbit
10-21-2022
10:54
08:13
AndreaFitbit
charger 2 will not charge when plugged in. cleaned tip of charger.
10-22-2022 08:18
10-22-2022 08:18
Welcome to the Fitbit Community, @Roger53. I'm sorry to hear that your Charge 2 will not charge when plugged in and thank you for letting us know that you cleaned the tip of the charger.
Please follow these steps to charge your tracker again:
Make sure you use the charging cable that came with your device, as most cables aren't compatible with other devices.
Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
Best Answer11-02-2022 01:38
11-02-2022 01:38
Dust and debris can accumulate over time. Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device? The USB port or outlet is faulty. Try a different USB port or a UL-certified wall charger.
Regards,
Will
