12-09-2020
12:59
14:58
EdsonFitbit
12-09-2020
12:59
14:58
EdsonFitbit
My charge 3 has stopped vibrating. Extremely annoying because i need those reminders to move or when I have hit my minutes goal when working out. I have made sure the vibration is on strong; the do not disturb etc wasn't set on my accident, reset my fitbit, unpaired then repaired it and checked all my settings. Anything I may be missing? Maybe its time to use my warranty and have it replaced?
12-09-2020 14:58
12-09-2020 14:58
It's great to see you in the Fitbit Community @Theanie.
Thank you for the information provided and for trying to resolve the issue before contacting us.
Before going any further, please let me know if your Fitbit Charge 3 doesn't vibrate when you get a notification, set a silent alarm or when it is plugged into the charging cable.
I'll be waiting for your response.
Best Answer12-10-2020 06:08
12-10-2020 06:08
I've checked what the moderator said and my Charge 3 doesn't vibrate now for any push or email notifications or when plugged in. Have you replied to the moderator about yours? Any answer?
Best Answer12-10-2020 07:37
12-10-2020 07:37
No, it doesn't for any of the above listed. Its completely silent.
12-10-2020 07:38
12-10-2020 07:38
Just replied back to moderator and awaiting answers
12-10-2020 08:14
12-10-2020 08:14
This is also a new issue from me and I've tried all the fixes and ideas noted above. Did Fitbit send an update or something recently, perhaps?
Best Answer12-10-2020 09:48
12-10-2020 09:48
Contacted Chat for help. Had to plug Charge 3 into charging cable, hold down button on tracker for 8 secs, release. Hopefully to then see smiley face and tracker vibrates. I had to do a long restart, holding down button again but for 15 secs this time until saw progress bar. Then, when bar complete, removed. device from charger but put it back immediately. Got the smiley and vibration! Yay!
Best Answer12-10-2020 10:46
12-10-2020 10:46
Glad you got yours working! I think mines just broken.
Best Answer12-10-2020 12:15
12-10-2020 12:15
Thanks for your responses @Yani22 @murraya8 @Theanie.
@Yani22, I'm glad to hear that you've been able to fix your Fitbit Charge 3, thank you for letting us know.
@Theanie @murraya8, in addition to the regular restart, you can also try a long restart by doing the following:
Please let us know if you have any question.
Best Answer12-10-2020 12:34
12-10-2020 12:34
Yes I tried this and still no vibration.
12-13-2020 16:32
12-13-2020 16:32
@Theanie, thank you for the update.
To evaluate this situation, I created a case with Customer Support. Please check your inbox on the next days. They will let you know how to proceed as soon as possible. Thank you for your patience.
If you have any question, please let us know.
Best Answer06-11-2021 07:43
06-11-2021 07:43
Same here mine show DND and sleep then the smile comes up again
06-12-2021 09:07
06-12-2021 09:07
I set an alarm and it went off and vibrated but won’t vibrate for any notifications
