01-16-2020
17:28
10:30
01-16-2020
17:28
10:30
What should I do?I have been using it for 12 months.
01-17-2020
08:42
07:57
01-17-2020
08:42
07:57
@Mottunni Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your Charge 2 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
