02-22-2017
18:04
17:01
02-22-2017
18:04
17:01
My fit bit works if I do a timer, it vibrates, and it is connected to my phone but the screen won't light up.
Any recommendations?!?!
Hello @Gwennoth, I’m very excited to welcome you to the community forums! My recommendation to fix the display issue is to perform a restart to the Charge following @AlejandraFitbit's instructions. Once you're done with the previous steps the display should be working properly, if not, please let me know so I can investigate further about this issue.
If you need more assistance don't doubt to reply. ![]()
What's for breakfast?Check others recipes and share yours!
Best AnswerHello,
I am having the same problem with my fitbit charge and have tried the rest but still have a black screen. Any other suggestions?
I have the same problem, it doesn't light up when charging also...
What else can I do?
Best Answerjust got a new charge 4 and was following setup and then screen went off, and now it wont come back on. I can feel vibrations when I push the button, but nothing happens
