02-01-2020
18:32
17:16
02-01-2020
18:32
17:16
I purchased a new Charge 3 just for the announcement of the sp02 feature during sleep. I’ve been tracking my sleep since Jan 2015 using Charge 1 to Charge 2 and now Charge 3. I’ve been reading the forums here to try to self resolve this and I’ve already tried to reset the watch a few times based on the instructions given and this morning again I woke up with no Sp02 chart. How do I enable Sp02/blood oxygen monitoring/estimation on Charge 3? My watch firmware is running 20001.63.5 and on a IPhone 11 Pro Max running the v3.13 of the app. Please help!
02-01-2020 19:38
02-01-2020 19:38
"How do I enable Sp02/blood oxygen monitoring/estimation on Charge 3?"
You just have to wait until it is finally released. No resets are going to get you something that is not out yet.
Best Answer02-01-2020 19:49
02-01-2020 19:49
Best Answer02-05-2020 15:02
02-05-2020 15:02
Hi Fitbit Support,
I’ve checked with my colleague who has a Fitbit Charge 3 and he as the sp02 graph in his sleep report. See the screenshot I asked him to send me, please let me know how to fix my issue. He is using IOS on an IPhone 8 Plus.
02-06-2020 00:52
02-06-2020 00:52
I see the red and green light daily when I wake up. I assume this is part of the sp02 data which I don't see yet either. I'm wondering if it's legal for them to keep this info from me in European law.
Best Answer03-15-2020 06:11
03-15-2020 06:11
Mine started to appear with the SP02 chart a few weeks back now. It also populated the SP02 charts for the dates since I started to use the Charge 3!
Best Answer03-15-2020 11:05
03-15-2020 11:05
this is not a SPO2 chart. do you see any Blood O2 saturation percentages. what is the chart showing you? basically nothing
Best Answer05-02-2020 05:43
05-02-2020 05:43
Did you find an answer as to how to get this feature to work? My charge 3 does not populate with information either.
Best Answer05-02-2020 06:30
05-02-2020 06:30
I just ensured it had the latest firmware and reset the Charge 3 and after a few weeks the charts just appeared.
Best Answer05-02-2020 06:33
05-02-2020 06:33
Switched from Blaze to Charge3 yesterday. Slept with Charge3 (7.5hours). Sleep graph is populated with types of sleep. Sp02 is blank.
Did I miss a step (pun intended) ?
Barry
Best Answer05-02-2020 07:20
05-02-2020 07:20
Same thing happened to me switching from a Charge 2 to Charge 3. What I did was upgrade the Charge 3 firmware as the one which came with it didn’t have the SP02 feature enabled. Then I followed the reset instructions here (Link below), and then after a while (a couple of weeks), the chart appeared with data. Past days which previously didn’t show anything were populated with the SP02 graph data from the day I had upgraded the firmware too.
https://community.fitbit.com/xmnuz23762/board/message?board.id=charge3&message.id=121492#M121492
Best Answer05-02-2020 07:50
05-02-2020 07:50
Thanks for the reply.
Reset on my Charge3 firmware was a little different than described in the link.
I still put in charging cradle, held down button til smiley face appears.
I’ll see what happens tonight.
Barry
Best Answer05-02-2020 08:11
05-02-2020 08:11
Just spoke to support and did a reset. Hope this works!
Best Answer05-02-2020 08:45 - edited 05-02-2020 08:45
Linda,
Thanks for taking the time to contact support and reporting back.
Fingers crossed for us both.
Barry
Best Answer05-03-2020 18:58
05-03-2020 18:58
The smiley reset as mentioned above has fixed the SPo2 issue. Last night I did receive the Oxygen Variation graph.
Barry
Best Answer05-04-2020 06:16
05-04-2020 06:16
Yup. Mine works as well, after the reset. However, another issue popped up. Now my help article page only reads in a foreign language. Support showed me how to temporarily fix but every time I exit and come back again it reverts back to a non English language and have to fix all over again. 🤷:female_sign:
Best Answer05-04-2020 06:49
05-04-2020 06:49
Join the club!
My old Blazed worked on both iPad & iPhone.
New Charge3 will only Sync with one of them.
When I add the second device, first one stops Syncing.
Even if I shutdown Bluetooth on the first one and wait an hour before trying the second.
Barry
Best Answer05-04-2020 07:13
05-04-2020 07:13
I’m not sure if it’s only me, my Charge 3 Bluetooth breaks once while as well. Never had issues on my Charge 1 or 2z Can’t figure out what breaks it but the only way I’ve found to recover it is to reboot the device on the charge 3 via -> Settings, About, reboot device. Read other threads on BT stability issues on the Charge 3 so I suspect they have firmware issues which Fitbit haven’t fixed yet.
Best Answer05-04-2020 21:05
05-04-2020 21:05
Just restart it and it should be ok.
