01-22-2022
23:25
15:49
01-22-2022
23:25
15:49
hello - i‘ve got a New tracker (charge 4) - the old one tracker of my charge 4 has broken - but it doesn‘t Show anything - is it possibly that i have to Order a New charging System For the net tracker ? ?
01-24-2022 13:03
01-24-2022 13:03
The charging cable/system should be the same, for the same tracker. Didn't the new tracker come with a new charging cable/system?
I found that connecting the charge 4 charging cable can be fussy to get things aligned. I assume that you know how to connect the charger, since this is a replacement. If you are sure that the charging connector is properly attached to the tracker, could it be the charging cable, or the wall plug is defective?
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
01-23-2022 03:27
01-23-2022 03:27
The charging system for the same model is the same. Any reason why you think there is a need to order a new charging system.
01-23-2022 09:14
01-23-2022 09:14
Hi i‘ve Thought that i Must buy a new charging System When i have a new Tracker but the charging System is Working nor the new Tracker does Not Show anything ;-(
01-24-2022 13:03
01-24-2022 13:03
01-24-2022 20:41
01-24-2022 20:41
Hi - no the charging System is doing well also the wall Plug because i can charge my old Tracker which is broken ...
No i have got no new charging System because the new Tracker is a replacement.
01-25-2022 02:39
01-25-2022 02:39
Try putting the tracker into the charging unit and press and hold the side button for 8 seconds or so, until you sense a vibration and a smiley face greets you. This is supposed to restart the tracker.
01-25-2022 13:21
01-25-2022 13:21
Thanks - have still done this - unfortunately Did Not Show anything -.-
01-25-2022 16:42
01-25-2022 16:42
Just wondering ... can I see a pic of the broken parts of old tracker?
At the mean time, I think you should contact Fitbit Support again about the non-working replacement tracker.
01-25-2022 17:02
01-25-2022 17:02
Am just thinking if it is possible to salvage the parts from the new tracker to fix the old tracker 🙂
01-27-2022 16:05
01-27-2022 16:05
Hi @Kaki02 since this was a replacement, get back to customer service to let them know you're having problems.
01-27-2022 23:42
01-27-2022 23:42
Don‘t work ...
01-28-2022 06:18
01-28-2022 06:18
@Kaki02 get with customer support and let them know https://myhelp.fitbit.com/s/support?language=en_US
01-28-2022 06:49
01-28-2022 06:49
Thanks , still done this / live Chat does Not work - i asked me why ??? But i have Sent an E-Mail to the Support too - and got answer.
01-28-2022 07:13
01-28-2022 07:13
@Kaki02 you all set up now?
01-28-2022 07:37
01-28-2022 07:37
No it does Not work but i am still in conversation with the Support ... via E-Mail
